4l60e 1st and reverse only
Old Dec 21, 2016 | 10:15 PM
mrvedit's Avatar
Moderator
Glad that Jays is willing to help and pull his own hair out (which I am running short of).
Everything he says is exactly correct, especially that it is nearly impossible for a 4L60E to start in 1st with the harness disconnected. The idea that it is starting in 3rd and slipping badly didn't occur to me but is a plausible possibility.
Else both shift solenoids are somehow stuck in the ON position.
Old Dec 21, 2016 | 10:23 PM
cleenrob's Avatar
im going to do some checking around but i think at this point its beyond my level of knowledge to try an fix myself as much as i hate to admit it.
im going to fiddle with it till mid-next week then ill take it to a shop and let them scan it since they know what they're doing/feeling
Old Dec 22, 2016 | 05:12 PM
Jays_SSZ28's Avatar
I am. Sometimes I kind of wish I could just look at stuff like this.
Old Dec 23, 2016 | 04:46 PM
cleenrob's Avatar
update:
ok so i pittled around with the wiring a bit figuring out a misfire, decided to take it for a spin to se what it would do and it finally shifted once i hit around 35(i dont think this had anything to do with the wiring as i only dealt with coil power)
so it seems like i have 1st and 3rd it took some feathering of the throttle to get it to shift at all
where should i go from here?
Old Feb 9, 2020 | 02:01 PM
Daniëlo Do Rego's Avatar
@cleenrob I know it's an old thread but my 4l60e is doing exactly the same thing you mentioned here. Did you ever solve the problem??
Old Feb 9, 2020 | 06:07 PM
vorteciroc's Avatar
Should the Transmission condition be:
First gear and Third gear ONLY (WithOUT Reverse, Second gear, and Fourth gear).
Then most likely; the unit may have a failed reaction sun-shell/ sun-gear...
This is one of the most Googled (or other Search-Engine) topics for 4L60E/ THM700-R4 transmissions,
ever since the internet became a common household service back in the early 1990s (Transmissions have been in service since 1982).
Old Feb 10, 2020 | 07:05 AM
MaroonMonsterLS1's Avatar
https://ls1tech.com/forums/automatic...-2-r-only.html
He posted an update in the thread listed above
Originally Posted by cleenrob
hey every one, just wanted to let every one know what was wrong with the trans:
the 2-4 band was worn out, it caused damage to the reverse input drum. and the 3/4 clutches were toast.
had it rebuilt and its all good now
He was last active on this forum in 2017...don't expect a response from him.
FYI, if people learned how to search the forum effectively...they would have a world of information at their fingertips
