Converter rated by HP not Stall
My thinking was well for 200 dollars more I get a converter that's rated for more hp and its going to be a stronger better build converter. Obviously I was wrong with this thinking but im wondering if this is a big mistake.
Did I get the wrong converter ? I don't want my car to be a dog do to a wrong converter . I don't really care if its going to make it just a tad bit slower but if its going to be a noticeable difference I guess it would matter to me. Thank you guys in advance.
further more we offer custom designed converters incorporating our power adder and boosted application stators that allow the turbo to spool easier without having the ridiculously high stall range.
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
you can always come back here with results and let us know how it did. Im sure we'll be able to give you our opinions on what you may or may not leaving on table.
Happy New Year!
-Dalton
1-866-726-8358
FTIPerformance.com
Kfactor= stall speed/ sqrt(torque). So if you have half the torque the converter is rated for you won't get the same stall.
Take for example a BM 3000 holeshot. Behind a mild 355sbc it may stall at 3000, behind a stock 283 it may stall at 2200 because the smaller motor just can't make the tq to turn any faster, but that same converter behind a 572bbc may stall at 5500rpm
Turbo motors can be tricky since we can build a lot of boost on the two step, and the technology these days has gotten way better that proper converters can be built
As FTI mentioned before if you have a free re stall if you have a torque curve or a guess at it they can probably re stall it to be more friendly.
I don't think it's a matter of the parts won't work just that it will be off for you power level.
I really like the Yank Truck Thruster 2600 in our Procharged TBSS. Blew some minds with a series of 1.6 60's in a 5100+lb truck.
Engineers say HP is Torque over Time, or that torque is an instantaneous measurement of HP.
Physicists say that HP is a direct measurement of energy (1 HP = 745 Watts).
