Cricle d stall problem
Old Mar 14, 2017 | 07:31 PM
Oldgtonick's Avatar
Default Cricle d stall
i brought a cricle d stall and when I put it in it Dosent free spin it get caught up about half a turn. Is it the stall??
Old Mar 14, 2017 | 08:27 PM
Oldgtonick's Avatar
Default Cricle d stall problem
I brought a cricle d stall and just put it in and it Dosent spin freely I can spin it about half a turn and it will lock up and can't spin it anymore anyone know what the problem is?
Old Mar 14, 2017 | 08:55 PM
JakeFusion's Avatar
Super Hulk Smash
Moving to automatic section.
Did it go on 3 clicks? Also, you need to measure the depth to make sure it's seated all the way.
Is the transmission installed to the motor yet?
Old Mar 14, 2017 | 09:03 PM
Oldgtonick's Avatar
No the trans isn't in the truck yet and it's seated all the way
Old Mar 14, 2017 | 09:34 PM
JakeFusion's Avatar
Super Hulk Smash
Did it measure 1.125” from bellhousing to converter pads using a straight edge/caliper? It can vary upto .050" I believe. But you need to check. You can damage the transmission otherwise
Old Mar 14, 2017 | 10:57 PM
wht/73's Avatar
Was the converter seated ALL the way in prior to bolting trans up?
Old Mar 15, 2017 | 02:00 AM
unit's Avatar
The converter should spin freely on the trans both before and after it's installed in the car. If you installed the converter on the input shaft of the trans but didn't get it seated completely and then installed it in the car, you may have damaged the pump in the trans. When that happens, the converter won't spin, which is a sign that the pump was damaged during installation. If that's the case, the trans will have to be pulled and the pump repaired before you can proceed. It could be something else, but damaged pumps are a common occurrence.
Old Mar 15, 2017 | 04:05 AM
Game ova's Avatar
As long as it isn't requiring a ridiculous amount of force to turn it's fine. Just went through this a few weeks ago, wasn't a circle d converter but it was the same thing you are describing. It's not a big deal. But the others are right, make sure it's locked into the pump....if it isnt....the pump will be destroyed nearly instantly. But at the same time, you don't want it bottomed out in the pump either.
Old Mar 15, 2017 | 02:30 PM
Oldgtonick's Avatar
I took the trans to the builder and he said the stall looks good it's the trans pump was broke getting it fixed rn... thank y'all for y'alls help!
