Decode this 4L60e "4cfd020"
Old Mar 25, 2017 | 11:40 PM
10SecondS10's Avatar
Default Decode this 4L60e "4cfd020"
Can someone decode this 4l60e " 4cfd020 "
Originally I thought it came off a 97' C1500 as per the seller (Rebuilt 10K)
Sold the trans to someone with a 97' C1500 but it was noticeably different than his
He found the " 4cfd020 " serial code and told me it was for a 94' Chevy C3500
Can someone kindly validate this? Also provide some info such as what years are interchangeable, what truck models it's interchangeable with, and worth?
Old Mar 25, 2017 | 11:48 PM
98CayenneT/A's Avatar
1994 is correct
Old Mar 26, 2017 | 12:25 AM
coryforsenate's Avatar
If it's a '94, I think it's pretty much only compatible with other '94 parts. Maybe some from '95. The first two years ('94-'95) of the 4l60e were weird years until it became more settled with the '96, which changed again in '98 I think and uses a different input shaft.
mrvedit and the expert mechanics on the forum could tell you for certain.
Old Mar 26, 2017 | 10:36 AM
Originally Posted by 98CayenneT/A
1994 is correct
How did you break down the code?
Old Mar 26, 2017 | 10:37 AM
Okay but does a C3500 and C1500 share the same 4l60e RWD?
Old Mar 26, 2017 | 11:25 AM
mrvedit's Avatar
Moderator
The leading "4" tells us its either 1994 or 2004.
Assuming the case includes the bell housing (and not separate), it is definitely a 1994.
What are you intentions with it. As said, it basically only works with a '94 PCM. It won't work with a LS-engine PCM. Maybe if the pump and valve body were significantly upgraded or modified, but be more trouble/expense than its worth.
Old Mar 26, 2017 | 02:41 PM
Thanks for replying. The 4l60e is not for the LS at all. I'm trying to figure out what the rest of the code exactly means - so I can sell it to the appropriate buyer - to help fund my LS project.
Old Mar 26, 2017 | 06:49 PM
mrvedit's Avatar
Moderator
This thread lists the 4CFD as coming from various GM 2500 trucks:
https://ls1tech.com/forums/automatic...-came-out.html
The "4" means 1994, the "D" means 4L60E and the "CF" is the vehicle.
This site might help you decode the "020":
http://southernperformancesystems.co...ans-codes.html
