4l80E low gear
Old Mar 27, 2017 | 03:18 PM
75nova's Avatar
Default 4l80E low gear
Hi guys ! Hey I have a problem with a 4l80e.
If I manually shirt into low gear it acts as though the tranny is bound up. if coasting VERY slowly it will even stop the truck.
It is in a 1997 dually with a 454.
when I shift start with the selector in "D" and use little throttle it will act as though it is slipping until it reaches 2nd gear. If I accelerate at say half throttle it will act normal. I can easily spin the tires from stop so I really don't think its clutches.
Any advice ?
Scott
Old Mar 27, 2017 | 04:01 PM
82cetuner's Avatar
sounds like a shift solinoid
Old Mar 28, 2017 | 12:28 PM
imisspontiac's Avatar
One of the most common 4L80E problems is a bad solenoid. There are 8 solenoids in the 4l80E and it sounds like it's either not sensing the proper pressure levels, or the pressure is off. Good luck.
Old Mar 28, 2017 | 12:37 PM
82cetuner's Avatar
there is a valve that is known for sticking also, or the little filter clogging up in the valve. id definetly look into the valve body components, pull it and test all the solenoids and check the valves too.
Old Mar 29, 2017 | 10:52 AM
75nova's Avatar
What valve is know for sticking? is it possible that I have a cross leak somewhere?
Old Mar 30, 2017 | 10:48 AM
82cetuner's Avatar
i forget which one it is. theres a couple youtube vidios that go over it, one is 2 hours long but if you go to the 1:30 mark it shows the beginning of the valve body build and repair.
just google 4l80e rebuild.
Old Mar 30, 2017 | 11:52 AM
75nova's Avatar
Is it possible something in the low/reverse accumulator is causing this problem?
I REALLY need some help here guys..
Thanks for the advice !!
