4l60e Trans Issue
Whenever I'm in stop in go traffic for awhile...over 20 miles...the trans will start revving high before shifting. 3K for the 1-2 shift instead 1.5K. It'll also downshift harshly. It only does this when warm & I've been driving for quite awhile. Engine coolant temp never gets over 205. It won't do this on short trips around town or a blast down the highway in no traffic.
Any ideas? TPS sensor bad? Is it just low trans fluid level? I guess I should check the level first before anything.
Does this mean it's the TPS sensor...maybe the torque converter is going bad? I feel like the line pressure just goes nuts if the car's been running in heavy traffic for awhile.
Hook up a simple scanner and read the TPS position. With ignition on, engine off confirm the TPS reads between 0% to 95%+. A fancy scanner, like HP Tuners, can read the MAF frequency to diagnose the MAF too. A fancy scanner, which a trans shop will have, can also confirm that the PCM is commanding the late shifts.
When the engine is on, at first it shows 0 - .4%, but it slowly creeps up to .8%, & then after about 20 mins of driving in traffic, the lowest the throttle percentage gets to is 11.8%. This is with foot completely off the accelerator. Even measured it on Park as well...still 11.8%. Engine temp is never over 205°.
Does this look like a bad TPS?
New drive-by-wire system do read up to about 8% at idle because there is no IAC.
So, since I think your '01 Z28 is drive-by-cable, it does sound like a TPS or wiring issue.
