Buick trans to ls
Old Apr 11, 2017 | 08:46 AM
LOWnEASY's Avatar
Default Buick trans to ls
I'm working on a trade deal, and included in the deal is a built th350 trans, that has a olds bolt pattern. Specs are:
Turbo 350, Olds motor bell housing. 4 passes.
Reverse manual valve body, transbrake.
It has all green clutches, 5/5 clutch packs, and 36 element drum. Big pan, Hughes scatter shield and dipstick. Works perfectly fresh build
I'd like to run it behind an ls, I would sell and get a different trans but seems it might be a tough one to sell.
so are there and adapters or way to swap bell housings? Guy said something bout laser cutting and welding on new bell but not sure on that one.
Old Apr 11, 2017 | 12:40 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
You can cut the bell off and go to an Ultra-Bell bellhousing.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Apr 11, 2017 | 12:41 PM
LOWnEASY's Avatar
I'm guessing a good trans shop could do it? Or is the a diy trick?
Old Apr 11, 2017 | 02:18 PM
forcd ind's Avatar
They make a thin adapter, as I remember a couple of the holes line up
As said, a new bell housing will work, bolts to the front pump
It prob wouldn't be a tough sale, it will fit a BOP, so there is some
desire for it
Old Apr 11, 2017 | 08:16 PM
mrvedit's Avatar
Moderator
I agree that its probably not a hard sell. I suspect there is a relative shortage of BOP transmissions and therefore seems a shame to cutup a "rare" item to turn it into a "common" item.
Old Apr 11, 2017 | 08:21 PM
LOWnEASY's Avatar
I may not cut it up, may try and sell first
not really sure what it's worth... 1k?
Old Apr 18, 2017 | 08:28 AM
Docrocket1967's Avatar
You could contact Advance Adapters for a Engine to Transmission Adapter for that.
