Upgrading my th400
Old Apr 14, 2017 | 10:17 AM
Game ova's Avatar
Default Upgrading my th400
So I've decided to upgrade my tranny. I'm replacing the direct drum with the stronger 4l80 drum with the good sprag. I'm also running a Tbrake so I need the bleed hole behind the piston. The drum has what looks to be a bleed hole already, is this really what it looks to be here in this pic? Was tired of short shifting to be easy on the roller clutch.
Old Apr 18, 2017 | 02:53 PM
Cwarta's Avatar
I did the same as you wth the 80e drum/sprag and drilled a second as per my instructions
Old Apr 18, 2017 | 02:58 PM
Game ova's Avatar
Yea, I went ahead and pulled the piston and drilled another hole. Was just trying to avoid pulling the piston, but as it turns out....I cant use that piston anyway.
