4l80 or 6l80
Since your doing a fox body I assume fast is the goal..
So for that a th400/700R4 family unit would be my pick. Trending Topics
I went with an 80E vs a 60E because there are FAR fewer post about them puking when pushed and watched my buddy drive his 470ci/625hp GS Buick to the track and click off low 11's and drive it home with no issues, sold me.
While my car was on the trailer (I could have drove the 45mi there) I couldn't keep up with my friend in the Buick.
I broke that day. THAT'S why I trailer it. The S clip fell off the manual valve in the VB and was stuck in 1st.
I have't been to the track yet to see if it has cost me any ET....but it sure feels exactly like
the t350 EXCEPT my rpms are very tolerable when I do go on the highway now.
The gearing is only .04 difference so that's a good thing too.
My 406 actually get good (for what it is) mileage now too.
I actually go deliberately out on to RT 80 now every time I take it out.
So IF it cost me a few .1ths it's well worth it to me.
If I want to remind myself of the 3 speed, I leave it in 3rd with the converter unlocked (doesn't lock till 4th and 45 mph) then I go whew, and click it up 1 more!
My car is a different scenario then most of the guys on here as their gearing is MUCH lower numerically then mine so that will help keep the rpms on a 3 speed down I guess but it's still not OD!.
Track car only..I could see the 3 speed tho.
So the 1st 3 gears are practically the same.
My van has the 6sp with a 4.8 and like you mentioned 3.42's.
It needs more gear.
I don't care what transmission or what gearing is in the trans.
I don't even have half the material in it that the old van use to carry around.
When my Nova downshifts, you'd better be holding on to something.
I guess that's why they make blue cars and red cars. LOL
What is ok for somebody might not be good for someone else.
I know the 700R4 isn't as strong as a TH400,, but I like as a cross over and it can be a decent transmission, maybe not 1200HP strong but it doesn't require the extra stuff to make it go, and if you want to run deep gears the OD is handy for the street drive.. And the parts are cheap..
So in a lighter vehicle and a larger engine I would like it.
Put the weight back in it and forget about putting the air on and I have to start flooring it again!
