Torque converter / stall?
I've got everything I need performance wise I want on my ls1. I'm just stuck on what stall/converter to buy.
mods
TSP 2.5 5.3 Heads milled to 63cc
fast 92 intake/ PTM 92 TB
Magic Stick 3 MS3 Cam Camshaft 237/242 .603/.609 111
fast fuel rails & fuel line
SLP lid
Melling HP oil pump
42lb injectors
ANY info would be appreciated.
thank you
mods
SLP lid
Melling HP oil pump
42lb injectors
thank you
With the PT series nitrous really is not a option unless it's on the smaller size and other variables. But yes the SS series handles nitrous much better than the PT series.
why would anyone go with the PT series over the SS series? If they are the same thing but the SS can handle nitrous why not get it?
When I talked to Dave at yank he said the SS 4000 will 60' better but the PT 4000 will trap higher due to it's higher shift extensions.
I do plan on spraying a bit eventually but will probably only be able to do 100 shot with my 6800 shift points, my shift extensions are at 6100 rpms.
Where as with a SS 3600 many people spray a 150 with stock shift points and some get away with 150 shot on the SS 4000 with stock shift points and some blow threw the converter.
With stock shift points and a PT 4000 it is just to loose for a 150 shot and will push the converter right off the rev limiter.
Now again, I would call Dave at yank but I would imagine you would be more than fine spraying a 150 shot with the SS 4000 with you spinning it to 7000.
SS is an inefficient converter. 15-18% slip uptop (83-85% efficiency). I'd look at the PAS series if you want to spray. They are more efficient uptop (93-95%) and tight for regular driving. The 3800 would work. Same cost as the SS.
Another option would be the CircleD 4C Triple Disk. It's a 3600-3800 stall... and with the triple disk you can lock it WOT in third on the spray. You'll be faster doing that. Otherwise you need to spray out of the hole. But that's one reason the 3400-3600 stall triple disks are used for the turbo and sc guys. They can build boost with the stall and then lock it to gain 100-120HP uptop (100% efficient).
Or I'd call PTC. They'll build you something custom that'll work better than anything else. FTI is in that boat too. And they have a triple disk setup as well.
If you want NA performance, you need a loose stall that has a lot of shift extension. CircleD 3E or PT4400 so you're only dropping 800 RPM or so on the shift and are 95% efficient. But they are loose driving around. Say 3k+ to stay up with traffic with 10% throttle. Going to an SS3600 or 4C would be 500-800 better in traffic, but slower at the track NA. Nitrous will go right through E or PT and push them to 6000+ stall.
So to recap in order of price (least to most):
PAS3800
PTC Custom
FTI Custom
PAS3800
PTC Custom
FTI Custom
PAS3800
PTC Custom
FTI Custom
PAS3800
PTC Custom
FTI Custom
OP, I agree with the above information that Jake posted, I think he provided some excellent options depending on which path you take.
mods
SLP lid
Melling HP oil pump
42lb injectors
thank you
mods
SLP lid
Melling HP oil pump
42lb injectors
thank you
PAS3800
PTC Custom
FTI Custom
PAS3800
PTC Custom
FTI Custom
Re: Dave @ Yank
That is not correct information if the SS converter has at least 800-900 rpm drop on the WOT 2-3 shift it will stay fully coupled up. At that point the converter unlocked will have around 5% slip and that is it the same as a PAS series. The PAS series just couples up quicker which means you dont need to shift the rpm as high to get the same 800-900 rpm drop you need on a mile setup. That is why we will tell people it works better with a power adder like spray turbo ProCharger etc.
-Yank Converters
Thank you for the really good info guys. After reading all of that I'm going to go with the yank PAS 3800 with lock up. My Fbody is just a weekend cruiser that I may take to the track a couple times. But I do have plans of hooking a bottle on it sooner or later.
