Best Flexplate for Long Crank Lq4 w/ 4l60e converter
Anyone have any part numbers or recommendations for a flexplate I might be able to use for my long crank lq4? I will be running an LS 60e and will have the snout on the converter cut down so it works properly.
LS1Tech Sponsor
To the OP: We recommend and only trust Meziere for all of our flexplates. If you're looking for the very best and don't min spending the money then Meziere is the way to go.
http://ftiperformance.com/1-Piece-Bi...tyle-FP300.htm
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
LS1Tech Sponsor
An easy option to eliminate ALOT of the guess work you have going on here is to make sure you go with an aftermarket converter such as our SRLS series that has all 3 bolt patterns (Small GM, Large GM(Also 4L80E/LT), and LS)
http://ftiperformance.com/Street-Rac...?categoryId=-1
with a converter such as ours all you have to do is make sure you get a flat flexplate to fit your crank and you'll be all set.
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
