4l85 question
Old Jul 12, 2017 | 10:44 AM
Motown 454's Avatar
Default 4l85 question
I have a 97 and newer 4l85, it has the long gear range selector coming from inside the trans that the shift lever connects to. Can it be changed to the short one without removing the valve body. Any help would will be greatly appreciated.
Thanks
Old Jul 12, 2017 | 07:49 PM
clinebarger's Avatar
Use Sonnax 38511-03K https://www.summitracing.com/parts/sox-38511-03k
You "CAN" bend down the separator plate & remove the nail to get the shift shaft out, Then bend it back to hold the nail in place......I would never do that to my or a customers transmission, I would remove the Valve Body.
Nail
Separator Plate covering it
Old Jul 12, 2017 | 08:06 PM
Motown 454's Avatar
Then I won't do it to mine either.
The long selector is butting right against my drivers side header and the linkage has no room to move into park because of the 02 bung.
Old Jul 12, 2017 | 08:35 PM
LOL......Are you open to pulling the unit down a little to do some hydraulic modifications? That is IF this is a STOCK GM 4L85E.
The only reason I bring this up is......A well tuned LSA & no torque management WILL slowly kill the Direct Frictions.
If you do not want to pull the unit to internally dual feed the directs, PM me...... I can sell you a Trans Go 4L80E HD2 separator plate dirt cheap that will dual feed the directs without removing the unit.
Old Jul 12, 2017 | 09:31 PM
wht/73's Avatar
Is this plate modded by you to do this or the HD 2 plate has it done from them?
Old Jul 12, 2017 | 11:36 PM
It's a triple layered plate that dual feeds the directs that comes in a 4L80E HD2 shift kit, I had a last minute build & used the intermediate snap ring & direct return springs out of a HD2 kit because it was to only thing I could get local.
Old Jul 13, 2017 | 06:01 AM
wht/73's Avatar
Ok thanks.
If motown passes, I'll take it!
Old Jul 13, 2017 | 06:47 AM
Motown 454's Avatar
Wht73 it's yours, I'm going to pass. Thanks clinebarger.
Old Jul 13, 2017 | 06:50 AM
wht/73's Avatar
Thanks!
What is the LSA/85E going in? Not the numbers matching car?
Old Jul 13, 2017 | 06:55 AM
wht/73's Avatar
I have the long shifter shaft also.
The plate that goes on the shaft for the Quicksilver shifter is real close to the collector flange but it just clears!
This is on a SBC tho..
Old Jul 13, 2017 | 12:29 PM
Motown 454's Avatar
Mine is going in a 69 Camaro the lever for the shifter is hitting the 02 bung. If I could get a lever that matched the B&M holes but bent in another 3/4" it would work like it is. don't know anybody to do the swap or cut a new lever with a bigger bend.
Check out the link at the bottom
Old Jul 13, 2017 | 12:44 PM
wht/73's Avatar
Can you move the bung so it clears? They are cheap.
Old Jul 13, 2017 | 04:04 PM
Motown 454's Avatar
The headers are already coated, and it would still be too close..
