4l80e cooler lines
What size are the cooler lines on a 99-03 4l80e? This is swapped into my 2k z28, I'm having clearance issues on the rear fitting and drive shaft tunnel, i found a pretty slick banjo fitting from sweet performance that would work great i think, anyone ever used them? Thank you.
I have a set of those banjo fittings, I wondered if they were restrictive if you didn't get the holes lined up-just blowing thru it and rotating the bolt I could feel a diff-if there were some thin spacers avail. you could add them to get the bolt to line up with the nipple. They may work fine as is, just something I noticed. I have used the ones from Middle Finger, they were fine.
On my Camaro.....I reused the stock "Cooler Out" 5/16" hardline by tweaking it just a little to match the stock "Cooler Out" fitting on the 4L80E case.
Stock 4th gen F-Body cooler lines are 3/8" at the trans fittings & neck down to 5/16".
Used a Sweet Performance fitting for the rear "Cooler Return" fitting at the Trans, Along with a 1/2-20 SAE Flare to -6AN fitting at the Radiator Mounted Cooler https://www.summitracing.com/parts/e...SABEgJFofD_BwE
I DID cut about 3/16" off the end of the Sweet Performance fitting because it was hitting the Center Support when torqued down....Check yours!
Used straight Aeromotive -6AN fittings & SS braided -6AN hose for the cooler return.
This is how I plumbed mine, 170-180 TFT in 100 degree weather with the A/C on...Driving the **** out of it!
![4l80e cooler lines-zbk4844.jpg](https://ls1tech.com/forums/attachments/automatic-transmission/719465d1683234631t-4l80e-cooler-lines-zbk4844.jpg)
![4l80e cooler lines-ben3hed.jpg](https://ls1tech.com/forums/attachments/automatic-transmission/719466d1683234631t-4l80e-cooler-lines-ben3hed.jpg)
![4l80e cooler lines-1odybm6.jpg](https://ls1tech.com/forums/attachments/automatic-transmission/719467d1683234631t-4l80e-cooler-lines-1odybm6.jpg)
Clinebarger,
Oh boy, I guess I should pull mine out and check?
Will the end of it be messed up? How will I know if it is hitting?
I guess it could block/restrict flow?
The hottest it's been was 174* when I was sitting following a school bus waiting.
It's been like this for 650 miles
Also, I "thought" the red (hot) line whould hit the rad cooler 1st then to the aux then to the rear port.
Doesn't really matter as it's working for you!
1/4" NPSM external thread diameter is around .526"
9/16-18 UNF external thread diameter is around .553"-.561".....Depending on the class.
I never saw the TSB on the change from 1/4" to 9/16" for 4L80E's don't know if this change ever actually happened with production models.
I run across this change on 4L60E's all the time & GM has a TSB on it.
Clinebarger,
Also, I "thought" the red (hot) line would hit the rad cooler 1st then to the aux then to the rear port.
Keep in mind that '97-early '99 center supports are different than Late '99 & up supports & the machining process could be different for the lube hole, Mine's a '97 model.
You should always check aftermarket parts!
I usually route to the Auxiliary Cooler first, It just worked out good for my car & great for my wallet. Most folks on here don't run a radiator mounted cooler.
