2nd accumulator bushing
I use a small dent puller that has a hook on the end.....A 5/16" nut with a manual valve link from a 700R4 welded on the side.
Hook it where the roll pin was, A few light taps will remove even the most stubborn accumulator bushings.
Got it out the other night. I was able to get a small bolt to partially thread into the end of it. I was able to twist it and wiggle it out. Probably not a proper way to do it, but it worked. Maybe this will help someone in the future.
