Help with Transmission Selection for LS6 in Rolls Royce
We are planning to drop an LS6 engine into an old Rolls Royce Silver Shadow. The car, from factory, came with a 3-speed automatic GM TH400 tranny with column mounted shifter. RR made some custom modifications to this transmission. The old transmission isn't any good and needs to be replaced anyway.
I have read on this forum that its better to go with a 4l80e or 4l60e as opposed to going with a replacement TH400, but I wanted to know which would be the path of least resistance. I've attached pictures of the old transmission we took out. It looks slightly different than your typical TH400, but which option would be closest in size and shape? I think the mounting bolts may also be in different locations.
Next, what's the best way to go from a 3 speed to 4 speed in terms of the column shifter and display?
The car will never be used for tracking or racing...but I imagine it will spend most of its time on highways.
Thanks in advance for your input and help.
What rear gear ratio are you going to run? I'm pretty sure the stock ratio is in the mid to high 2's, If your going to run such a tall ratio?.......Stay with a TH400, Just a Chevy version. You can install the Output Shaft & Tail Housing in/on a Chevy Case
From experience......LS6 5.7L's don't fare to well in heavy vehicles. The first gen CTS-V is a dog down low & I bet it doesn't weigh near what your Roll's weighs.
Another TH400 is definitely the path of least resistance.
However, if you did go 4L80E I would setup the column shifter to only select between 2nd and 4th gears. Unless you are climbing rocks, who the heck ever shifts into D1?
Will do if we stick with the TH400.
However to keep the engine noise down, a luxury car using a TH400 probably had a rear end ratio in the 2s.
With a rear end ratio in the 2s, as your Rolls probably had, you would likely want a larger displacement engine in the 6.2 - 7.0L range to give your the low end torque needed for smooth acceleration.
A higher stall converter will help with acceleration and I would recommend something in the 2800 range regardless of whether you go TH400 or 4L80E.
Just my 2 cents.
