Colonel, what is a reasonable tranny temp
The tranny was just installed and yes, fluid level is fine. I also am running a deep pan as well.
Thanks
210* seems high to me especially if the converter was locked. If the (4400) converter was unlocked and you were cruising at 3300 RPM there would be a lot of slippage and would cause the fluid temp to be high. Either way 210* is high for just cruising around.
I think that 170 to 190 is as high as you would want to see the fluid temp if you were just cruising around.
Coolant temps staying fine? Tranny cooler installed after the radiator or before (path of fluid is what I'm talking about.) And you're sure the converter was locked, right?
Kevin
Worst case, you can add another B&M cooler in the daisy chain and it will add additional cooling power. I ended up running a 24K and a 19K B&M daisy chained in order to help maintain the temps after adding the tranny blanket full time for the daily driver.
The nice thing about this was that I could hot lap 3-4 runs and keep the temps in the 180F range.
Rick
Rick
Thanks
Kevin
I had just picked my car up from the speed shop I do business with...where I had some engine work done. The tranny just kept getting hotter the longer I drove it...200...210...220...230...237...and I was not driving it hard at all.
I was really worried about it going beyond 220, and so when I got home I did some research on the forums to see what I could find on the subject. At first, I thought maybe my t-cooler was hooked up wrong, or had some blockage.
This was a "fresh" tranny with low miles, and it seemed I was burning the thing up just driving around like grandma. Well, I knew better than to get on it at all like this, as I would probably trash my clutches in that kind of heat...but no matter how I babied it, it just kept getting hotter. Finally, I got out of the heavy stop and go traffic I was in, and on to the highway. Immediately everything began cooling down! Well, while I was keeping an eye on the tranny temps earlier, I also noticed my engine temps going up along with the tranny.
Anyway, like I said, I got home, did some research, and can't remember whether it was on here, or on corvetteforum, that I read a thread about coolers tapped into a certain radiator line(can't remember which one), would cause the tranny temps to follow the engine coolant temps! I was like...hmmm...surely this GREAT speed shop I've done ALL this business with, would not overlook completely filling my radiator after some in depth engine work...would they???
You can see where I'm going with this...right? So, I go out to the garage...open my hood...check my water level...and you guessed it...it was WAY LOW!!!
So, I fill it to the PROPER level...I get in and go for a test drive, and PRESTO!...nice low engine and tranny temps ever since, regardless of traffic conditions or air temperature!!! Evidently, the engine temps were heating up the tranny through the cooler lines??? I don't know...I just hope nothing got too cooked in my newly built tranny!
I've never seen my speed shop(I'm doing them a favor by not mentioning their name) do this before, so I just blew it off.
During the next couple of weeks I have the car back in there to freshen up my heads, get it back...water level's too low AGAIN!!! So the customer fills their water level up yet again! Must be time to look for a new shop.
Hope this helps someone...and sorry for the length!!!
I have a few simple questions:
1.What was the exact outside temp that day?
2.What was the exact engine temp in relation to tranny temp?
3.Where your speeds under 45 mph(on the stall not locked up)with very little air flow (speed)?
4.Was the a/c on?(probably so since it was very hot outside)
5.Was your coolant tank Empty or not full to the rim?C-5 's are not supposed to be to the rim.
6.Once you started moving after 45 mph ,what did temps reside to?
7.How many miles on the car/radiator?Is it more than 50,000 (hope not)
All the above are more relavent to this topic than most think,For all who read this and post judgment about a reputable shop(which is plainly stated by the way) mis-filling coolant tank,take the above into consideration along with the mods.
I know for a fact the shop above does check out sheets 2 pages long on all cars before they are delivered,along with complete test drives before it can be signed off on.Been there and seen it done !
Anxiously awaiting answers to the above!
if you want please lock this thread so who ever is having issues with this so called no name shop can be addressed outside my thread thanks!!!
Kevin
Also, don't know why you think it's your personal business, especially when I haven't named the shop? What do you do, track people to determine their screennames, and what shop they might be using??? Also used more shops than what's in my sig...so don't bother going there!
That being said...here are the answers to your questions. Like I said...haven't flamed anyone by name here. As a matter of fact, I like all the guys in this shop, and there was a time I could have taken them to court over a very recent expensive issue(and still can, if I want to), which I won't name, but didn't because of my relationship with them. There have been other issues, but I haven't mentioned them. I'm human, let me be upset at my misfortunes, like everyone else...and I will be talking about them, when they happen to me.
1. Don't remember the exact air temp, but it was in the low to mid 90's. I have driven numerous times in this temperature and humidity without any issues before this, and with every mod listed!
2. The engine temps were consistantly within a few degrees of the tranny temps, at all times and during all escalating tranny temps! Don't remember the variance.
3. I already stated that my speeds were in heavy stop and go traffic...go figure!! The engine temps were rising rapidly at that time and began to cool off after I hit the highway! Why don't you go back and read my thred again before you start attacking me???
4. Yes, the a/c was on...brilliant deduction. Getting a little emotional over this aren't you???
5. It was not full to the rim or the oem mark, in a significant way. As a matter of fact...it took 2 quarts of water to get it to the "properly filled when cold" mark!!! Let me guess you want to keep defending this in vain, right?
6. Can't remember the exact temp here, but was just extremely happy the temps came down to a safer level. How is it you know who this shop is, since I didn't mention any names?
7. The car/radiator has about 85,000 problem free miles in regard to it's ability to run cool. It has never had a cooling issue, and doesn't have one now, thanks to me filling the radiator to the proper fill mark! The engine is a 2002, and has only 8,000 miles, and the tranny is fresh with only about 2,000. Anything else your highness?
The shop who did this, is a reputable shop, and I have bent over backwards for them on stuff like this, and many times have spent hundreds of dollars out of my own pocket, to just keep things on good terms with them...and let them rebound from some issues I'm not going to mention on this thread. They also have done things for me as well. Not trying to bash them.
That being said, I don't like people who won't take responsibility for their mistakes...and I don't appreciate you thinking I can't sound upset about this, on here or anywhere else. If I wanted to trash someone, I can do it with a vengeance, and on more forums than here. I'm not about ruining people's reputation, thus...no name for the shop...get it? Nothing wrong with relaying info about mechanical problems and where they originated.
If you don't work for this shop, I don't see how it's any of your business...and I don't appreciate you acting like I can't share my misfortunes with my car on here!
If you do work for this shop, relax, I haven't mentioned any names, and don't intend to. After all you and I are the only ones who know who we are, right? Chill out! In fact I still recommend people to this shop, only wish they would be more careful about certain details, before they return the car to the customer...and I happen to know the owner would agree with that!
On the other hand...if I find out you're affiliated with this shop, and are attacking your customer, instead of just saying, "oops, sorry for the oversight."...maybe I am being stupid for being so understanding.
I'll be curious to find out who you are.
Kevin, sorry this happened on your thread. Hopefully it will get locked before too long.
