4l60e 550 hp
Old Oct 20, 2017 | 06:49 PM
da7ome's Avatar
Default 4l60e 550 hp
hi I have a 2009 GMC Sierra 1500 with 5.3 and I want to make 550 hp and I have 4l60e 4x4
Old Oct 21, 2017 | 08:43 PM
clinebarger's Avatar
The problem is......Trucks are heavier than your run-of-the-mill performance vehicle like a Camaro or Corvette. If your going to beat the **** out of it.....Do a 4L80E swap!
Old Oct 22, 2017 | 01:00 AM
InYuco Katan's Avatar
http://cahallperformancetrans.com/#2787 this is the man for 4l60e. He will hook you up
Old Oct 22, 2017 | 03:54 PM
SlasherVRGR's Avatar
I agree, I have a 5.3 1500 and an LS1 Camaro. Car has full bolt ons and 243 heads, and 150 shot. Truck is bone stock.
Just Friday on my way to work the truck chewed up the sun shell, car is still kicking though.
Old Oct 22, 2017 | 10:17 PM
da7ome's Avatar
Thank you all for your inputs if I want to swap to 4l80e what do I need to do and keep in mind I'm not in the usa
Old Oct 23, 2017 | 07:20 PM
Do you want/need to keep it 4x4?
Old Oct 23, 2017 | 08:22 PM
da7ome's Avatar
Yes I need 4x4
Old Oct 24, 2017 | 09:05 PM
What is the 3-digit Transfer Case RPO on the SPID sticker in the glove compartment?
The Code will start with a NQ for part-time Magna cases & NR for full-time Borg Warner cases.
Old Oct 25, 2017 | 01:46 AM
da7ome's Avatar
I think it's NQH
Old Oct 25, 2017 | 10:04 AM
performabuilt's Avatar
LS1Tech Sponsor
Give us a call to discuss your needs we ship overseas all the time.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 25, 2017 | 07:41 PM
Originally Posted by da7ome
I think it's NQH
GM part# 19132978 is the 32 spline Input for the MP-3023 that's in your truck.
GM part# 15724745 is the 4L80E T-Case adapter (Round 6-bolt) you will need.
I use 2wd 4L80E cores with fully splined output shafts & cut the output to the correct length for the application using a band saw.
Section the crossmember & use some 1/4 plate to extend the mount area of crossmember back.
Trans cooler lines off/for a '01-'06 GMT800 2500HD will fit a GMT900 truck.
Add a external neutral safety switch over the manual shift shaft, One for a 2007/2008 GMT900 truck will work, You need the Connector/Pigtail as well.
Some wiring required.....It's not that much! If you decide to do this, PM me & I can help.
You may be able to reprogram your existing T42 trans controller, If not.....Used one's are not expensive
Both driveshafts reworked.
