Factory vs built trans tune differences
Old Nov 2, 2017 | 12:10 PM
BCNUL8R's Avatar
Default Factory vs built trans tune differences
I have an oem 4l60e with a yank 3200ss converter. The car was tuned when the cam and converter was installed. There is nothing wrong with the trans currently. I plan to install a procharger soon so I doubt the trans will hold up very long.
My question is... If I install a built 4l60e trans and reuse the same converter am I likely to have any tune issues transmission wise? If so what are some possible issues?
Old Nov 2, 2017 | 12:48 PM
BOLO's Avatar
Your built trans will not require any tune but you may need to have the converter restall for the pro charger. Then and only then, you may need a re tune as well for the pro charger and the stall.
Old Nov 2, 2017 | 01:59 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Your shift points may need adjustment, as the built trans will likely shift a bit earlier (this was my experience - quicker shift times with less slop led to earlier actual shift rpms at WOT.) But, you'll likely want to adjust shift points anyway with the new setup.
Old Nov 2, 2017 | 02:13 PM
ddnspider's Avatar
You also need to be careful with the trans pressures. if the shop that builds the trans increases the pressures mechanically and the tune already jacks the pressures up, you could end up with too much trans pressure.
Old Nov 3, 2017 | 08:26 AM
bbond105's Avatar
Like ddnspider said. Trans pressures can be raised with the tune and most "built" 4l60e transmissions have a larger boost valve installed that raises line pressure up into the 220 psi. range. As you can see installing a transmission that has a larger boost valve into a vehicle that has had the line pressure jacked up with the turn will put the line pressure dangerously high.
Old Nov 5, 2017 | 01:36 PM
performabuilt's Avatar
LS1Tech Sponsor
I usually suggest putting the pressure settings to stock if they have been changed, If the PCM was already tuned for the converter and shift point I do not think you will see or need to make any changes there .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 5, 2017 | 02:41 PM
01ssreda4's Avatar
My 1/2 light throttle got harsh with my upped pressure settings and HD2 kit. I knocked them down maybe 20% and it was fine. Everything else remained the same.
