2002 Chevy S10 ZR2 transmission problem
LS1Tech Sponsor
Hmm well if it stuck in forward assuming the outside linkage is moving and you can get park , IMO two possibly exist the manual internal linkage has disconnected from the manual valve or the forward clutch is fried and wielded itself together if its the forward clutch if you place it in reverse it will not move at all will be like brake applied ,
So I would say internal trans issue
__________________
