How to make a stock 4L60E survive high hp/track
Old 07-05-2019, 08:02 AM
  #101
MaroonMonsterLS1's Avatar
Received 1,254 Likes on 804 Posts
Originally Posted by bortous
I agree the 4L 80e is cheaper to build and can handle more power.
However the weight penalty of this transmission will ruin my handling as it's significantly heavier than the 4L60e.
How does the 4L80 E drive on road in every day traffic in terms of responsiveness and gear changes compared to the 4L60e?
If both units have been fully rebuilt with quality parts.
Does the 4L80E make the vehicle feel like a truck?
This just goes to show how clueless you are.
The 4l80e is NOT ridiculously heavier than a 60e.
The 4L80E weighs 178 lbs in typical configuration. A 4L60E weighs approx. 140 lbs, a TH400 weighs 135 lbs, a TH350 weighs 125 lbs. All weights are without converter and dry with stock components.
Back to back dyno between a 60 and an 80 will show less than 3% difference in HP (assuming both converters are spec'd properly)
The gear ratios are better in the 80e...not such a dramatic drop from 1st to 2nd that has always plagued the 60e
The gear changes are non-synchronous. Meaning one clutch just comes on after the other...no special timing for the release of one clutch during the application of another (like the 2-3 shift in a 60e) so the gear changes in traffic and on a day-to day basis (as well as when racing) are better.
Your ignorance is shining
Old 07-07-2019, 10:12 PM
  #102
bortous's Avatar
Thanks for the information about these transmissions.
You have cleared up a lot of information for me,
Don't forget this is a forum where you can learn knowledge as a lot of members have varying degrees of it in different areas.
What is not good though, is calling people names.
Clueless and ignorant because I don't know a lot about these transmissions. Only basic things.
Maybe it's true, but you don't need to be a DICK about it.
Learn to be a bit more diplomatic.
It's called etiquette.
Old 07-07-2019, 10:29 PM
  #103
Game ova's Avatar
Clueless and ignorant.
You've shown this, in an OVERWHELMING abundance. And btw, the very meaning of ignorance is "not knowing". Which again, has been well established.
Old 07-07-2019, 11:23 PM
  #104
bortous's Avatar
Ok.
If you wish to continue please do.
Get it out of your system.
Old 10-09-2019, 01:11 PM
  #105
EVILVEGA's Avatar
HI
Anyone knows if i change mi PCM with out program de VIN Number, the transmission will fail, i have an automatic Trans 98 and the 3th and 4th gers dont work, with the new pcm
Quick Reply: How to make a stock 4L60E survive high hp/track
