source for 4l80e input shaft & 34 element sprag
Old Nov 23, 2017 | 03:40 PM
truckdoug's Avatar
Default source for 4l80e input shaft & 34 element sprag
I will be shooting for 800 wheel next year. I'm reading some say that's the limit for the stock input shaft. I'll be adding a 2 step/retard so my launch will load the trans a lot more.
It's a 4.8-7875 turbo combo that did a best of 10.99 at 133 with traction issues. 4l80e is stock other than a hd2 kit. budget converter will get replaced with something in the $1k range (and an sfi plate)
I shift this combo at 7500. rev limited to 8k
I usually do my own trans work (with an ATSG and a lot of coffee)
I'm on a budget so I'm looking for someone like-minded to steer me to the right parts.
Gracias.
Old Nov 23, 2017 | 04:48 PM
clinebarger's Avatar
Check out CK Performance, At those RPM's.....A Aluminum Direct Drum is a good idea.
Old Nov 23, 2017 | 08:43 PM
onebadbowtie86's Avatar
Sorry cant help on the parts, but did you get the blue truck running 10.99? I need to get caught up on your youtube channel.
Old Nov 24, 2017 | 06:22 AM
truckdoug's Avatar
yeah it ran that first time out on 19psi, spinning at 300 feet. its a monster.
since then I have backed it off to 12-14psi trying to launch it better while not getting kicked out. still 60's in the 2.0 range
but I want it to launch hard, get a 9.9x time slip and sell it to fund my next project.
Old Nov 25, 2017 | 07:56 PM
Damn! nice job Doug! Someday I will get a turbo....
Old Nov 25, 2017 | 09:21 PM
squarles67's Avatar
CK Performance is where I got mine
Old Nov 27, 2017 | 03:39 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
DOUG, we have the 300M billet input shafts available! check it out and see if this its your needs and budget!
http://ftiperformance.com/4L80E-4L85...Parts_c157.htm
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Dec 10, 2017 | 04:40 PM
1500HP's Avatar
Ck performance is the man , I got a 4L80 e with all but one part he offers don’t have his new pump gears
