TH400 overflow catch tank/venting
And we have a pretty sweet setup that mounts directly to your trans if you want to check it out.
http://ftiperformance.com/searchquic...keywords=f2546
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
It just concerns me that maybe trans fluid may start leaking there while at the track. Should that be a concern? Or will that only happens if trans is overfilled? Too much pressure maybe? Just curious I guess.
My TH400 was tapped for an NPT fitting in the case where the overflow is.
1-866-726-8358
FTIPerformance.com
My PERSONAL opinion is "Better to have and not need, than need and not have." and for that reason I would run one. But if your trans is setup and working correctly then there should be no venting.
-Dalton
1-866-726-8358
FTIPerformance.com
