Help with converter choice
Old Jan 1, 2018 | 11:24 AM
69 nova's Avatar
Default Help with converter choice
I built a 66 nova put a lq4 with243 heads tick ls2 SNS Stage 2 can topped off with victor jr and a 750 holley. I put a 2004r behind it car will be a cruiser and occasional trip to track What stall would you run??? Car weighs 3000 with me in it and has 373 rear
Old Jan 1, 2018 | 11:29 AM
Jays_SSZ28's Avatar
Any reason you don't want to use their recommendations?
Designed for: LS2, LQ4 and LQ9 Engines (346-364ci) with Cathedral Port Heads (as they're equipped with stock)
Basic Operating RPM Range: 2000-6600
Expected Horsepower Gains: 50-60RWHP over the stock camshaft in a well-optimized setup
Expected Torque Gains: 25-35RWTQ over the stock camshaft in a well-optimized setup
Stall Converter Required: Yes, 3500+RPM
Rear Gear Upgrade Required: Suggested for maximum performance (3.42+ for manual transmissions and automatic)
Works Well with Nitrous: Yes (shot size less than 200)
Will Pass Most Smog Emissions: No
Old Jan 1, 2018 | 11:38 AM
69 nova's Avatar
I have tick recommendations but it just seems high I put a 3800 stall in it and it screams around town and smokes the tires when converter locks in. Don’t get me wrong it is fun but seems to me a 3000 stall would be better suited. Thought maybe someone has same setup as me and can give me a recommendation
Old Jan 1, 2018 | 11:41 AM
98CayenneT/A's Avatar
I would go closer to a loose 4000.
Get a set of radial slicks and good to go
Old Jan 1, 2018 | 01:13 PM
69 nova's Avatar
Even looser then the 3800 I have???
Old Jan 1, 2018 | 01:23 PM
You have a 3800 in there now and don't like it ?
I guess it comes down to..... do you want to make more power at WOT or less power at WOT
Old Jan 1, 2018 | 01:27 PM
69 nova's Avatar
I have a tci super street fighter 3800 lock up just seems very loose at in town speeds engine seems to rev a lot and there is no in between either slow or smoking tires in low gears
Old Jan 1, 2018 | 01:28 PM
69 nova's Avatar
So if cam makes power from 2200-6000 is lowering the stall to 3000 going to hurt the performance that much???
Old Jan 1, 2018 | 01:39 PM
If it were me I would get rid of that loose, inefficient converter and get a Yank or something comparable.
Something like a SS 3600, SS 4000 or PT 4000. They will all drive soooooo much better than that tci.
If you are looking for performance then yes, there is a big difference in those stall rpms
Old Jan 1, 2018 | 01:43 PM
69 nova's Avatar
So a yank 3600. I paid a lot for that tci it bolts directly to my ls from my 2004r can I get a yank that does that also ?
Old Jan 1, 2018 | 01:59 PM
Jays_SSZ28's Avatar
I had a TCI that was too loose everywhere.
I called a very well known company and they made a converter for me, they missed. It was just like the damn TCI except billet and $800+
Then I called FTI and they made one exactly like I wanted it. tight around town, damn near exact stall speed at wot.
So....not all 3800 rpm converters are loose around town.
Old Jan 1, 2018 | 02:03 PM
69 nova's Avatar
I spoke with tci last week they said they could tighten my converter up and lower the stall to around a 3000 was quoted 175-250$$ to do the work. I have over $500 in converter already had to spend another $800 for a yank
69 nova's Avatar
I bought converter from Texas speed
Old Jan 1, 2018 | 04:27 PM
bbond105's Avatar
TCI=JUNK Step up to a real converter. A good converter will be in the $800 range.
Old Jan 1, 2018 | 04:46 PM
69 nova's Avatar
Thanks that’s a big help
Old Jan 2, 2018 | 02:46 PM
How high are you going to be spinning your motor?
Old Jan 2, 2018 | 06:00 PM
69 nova's Avatar
It will be a street car not turning high rpms all the time. I spoke with FTi they said $795 for a new converter
Old Jan 2, 2018 | 06:07 PM
gesto's Avatar
69, I wouldn't spend good money after bad with the TCI. Call FTI, Yank or Circle D and have them spec a good converter for you. I have a 4000 rpm converter from FTI and it has good street manners as far as I'm concerned and when you hit the gas it makes a huge difference over the 2800 - 3000 converter I had before.
Old Jan 2, 2018 | 06:31 PM
69 nova's Avatar
I always thought TCI had good reputation I didn’t know they where so disliked by the LS car crowd. I always used them on my older sbc. That’s why I bought this one
Old Jan 2, 2018 | 06:41 PM
What size did FTI spec ya ?
FTI, Yank, Circle D, etc. will all be night and day vs that 10" TCI.
