4L60E EXPLOSION! What Happened?
I was driving to work one morning and started to go at the green light and as soon as I hit the gas things broke really bad underneath. When I got it home (1999 Z71) I found the rear differential destroyed. I replaced the rear axle and thought I was all fixed up but noticed a “warped” feel as I inched the truck forward. I pulled the transfer case and noticed I couldn’t turn the transmission output shaft while it was in neutral so I pulled the transmission and found the mess you see in the picture. The inner race and sprag or low roller clutch in the center support is totally destroyed
My question is this; what came first the chicken or the egg?
In other words…Did my tranny take out the rear end or the rear end take out my transmission? I’m guessing that when I hit the accelerator the back right wheel spun on the semi-wet road then the locker kicked in and that’s when the rear axle failed, the center of the carriage was broken not the ring or pinion…so my theory is the sudden rear axle crash took out my transmission…or am I wrong? Could it have been the transmission first?
I can’t afford this to happen again!
Thanks for your suggestions!
Seen many posts about tranny(both M6 and A4) destruction that had no effect on rear.
If the rear locks(breaks) and the engine is still applying power,something between the two has to go to relieve the pressure.
Many threads about sprags going.
Please tell me that you didn't put a replacement factory locking carrier back in. When mine went - just pulling away from a stop light, giving a light jab of the throttle - it sounded like a gun going off under my truck. Took it apart and there was deep mauling all over the housing itself even. Those things are dangerous.
It seems I keep getting snake bit, got me on both ends this time!
That's just a thought I'm putting out there I'd like your input on. I have read more that one thread mentioning rear axle/differential failure after transmission upgrades. Where do you cross the line at too much transmission for the drive train? You can definitely have too much motor for a drive train, right? It's like building a house on sand.
Basically all that for this...is high line pressure, corvette servo, etc. causing too much torque too quickly for the sloppy stock drive components in these heavy *** trucks?
Lost a rear end your, along with the driveshaft yoke. When I pulled the transmission apart to rebuild it.... This is how the roller clutch looked. And I would bet that yours now looks the same.
I am using a center support assembly and rear planet from a 2003 4L60E that I have, isn't those the same as my '99? Also using input drum from the '03 because it doesn't leak. The '99 transmission seems identical to the '03 except for sunshell and reaction shaft. The reason I'm asking is because the forward clutch pack is very tight, could this be because I'm reinstalling saturated used frictions not new ones? Also, very little end play at output shaft with pump installed, both transmissions had same selective washer. I can push the shaft in a few thousandths, probably .008" or so, then it springs back out. The shaft turns pretty easily clockwise and you can hear the sprags but it takes more effort to turn counter-clockwise...Is this good to go or no?
Thanks for any help!
Sure you can use most parts from the '03 in your '99.
The forward clutch should have about .030 clearance, not sure when less becomes a problem. How much do you have?
The input shaft end play should be .015 to .035. Obviously we want to aim for the smaller number. I've gone as little as .012 with brand new bearings and parts, figuring the final seating will be me a few thousands. But .008 sounds risky because it will tighten as the trans get up to operating temperature. You remembered the gasket between the case and pump?
Yes, I did install the pump gasket. The first time I built this transmission it had a really tight input shaft end play it just seems a little tighter now.
And sure, just like too much power you can have "too much transmission". But that's not likely what did you in. These lockers are grenades and it's just luck of the draw. Plenty of people have had them blow on stock, low mileage trucks. If you go onto some chevy/gmc truck boards you can easily see how prevalent it is.
It's kinda like the 7.5 ten bolt debate that's been raging for years. Some guys run 600rwhp through them without issue while some guys have them explode on the street with stock power.
Bottom line is - that locker is a time bomb and it;s not a matter of if, it's always a matter of when.
Now I shall comb the threads and posts to see what's the best locker to replace this junk with.
Thanks again guys!
I'm just commenting on the the G80 Gov-Loc (often called Gov-Bomb) unit's tendency to randomly and literally explode. As far as the trans goes, it lasted another year or so before suddenly quitting while driving 65mph on flat ground on the way home frm work one day. Ordered a new built one and put that in. No idea what it looked like inside, it's still sitting sealed up behind my house. For me, when a tranny goes you go out and buy a new one.
