Th400 swap
Old Mar 8, 2018 | 09:05 PM
Evanmarshall97's Avatar
Default Th400 swap
Alright guys I need some help, I have a 2000 z28 car with a 6.0 iron block bored to a 6.2, I have a built 4l60e in the car right now and looking for a th400. Someone near me has one that came out of his lt1 camaro and comes with converter and fill tube for cheap. I was wondering if this is a direct bolt in other than the crossmember and driveshaft fittament issues?
Old Mar 8, 2018 | 09:50 PM
MY_2K_Z's Avatar
Probably will need a flex plate, crossmember, driveshaft
Old Mar 8, 2018 | 09:52 PM
Game ova's Avatar
Bolts right up. Won't use all the bolt holes though.
Old Mar 8, 2018 | 10:33 PM
BOLO's Avatar
As mentioned, you will need a different flexplate. TCI #399753 or equivalent. You will also need a converter for your combo.
Old Mar 9, 2018 | 11:46 PM
So get a flex plate and stall converter and run it, sweet. What flex plate am I gonna be looking for?
Old Mar 9, 2018 | 11:52 PM
nevermind I see you posted in, thanks so much fellas, any other tips or tricks for while I’m installing it would be much appreciated!
Old Mar 14, 2018 | 02:28 PM
allblackedout5's Avatar
I am in the process of doing this right now...
As others have said..
You'll need proper flexplate/converter combo, driveshaft, trans crossmember, shifter, and you'll have to rig up a new vss input and loop some wires for neutral safety switch. Haven't done the wiring or shifter yet myself but everything else is in.
I bought all my stuff new from FTI and they sent me everything I needed with the exception of shifter and wiring.
