4l60e downshift
Old May 23, 2018 | 08:31 PM
Lee Cooper's Avatar
Default 4l60e downshift
picked up an Lt1 with the A4 and 190k on the clock. Its seems to me as the transmission is not downshifting as low as it should be. In OD at around 50 mph it just down shifts once and doesn’t seem to get into the powerband. Is there a down shift cable that could be adjusted or am I stuck with this till I rebuild the trans and install a shift kit?
Old May 23, 2018 | 08:42 PM
98CayenneT/A's Avatar
If you have 2.73 gears 1st will run you out to about 55 mph meaning if you are in 4th it is not going to downshift to 1st.
So what you are stuck with is downshifting to the very bottom of 2nd "turd gear" lol
Drive about 35mph in 4th and lay into it and it should hit 1st. 2.73's (if that's what you have) kind of suck unless you're going like 85 mph because 2nd runs you out to about 95-98 mph
Old May 23, 2018 | 08:51 PM
Jays_SSZ28's Avatar
Depends on the year. Early LT1's came with a 700R4 (4L60) These have a governor and throttle valve cable that determine shift points.
1994/1995 up are 100% computer controlled.
Old May 23, 2018 | 09:08 PM
Lee Cooper's Avatar
Ok sorry, it’s a 95 so it’s computer controlled. I’ll run that mph test tomorrow heading into post. Any gear combo make it better? Rear end needs to be rebuilt any way mad whine from botched 3.73 install.
Old May 24, 2018 | 12:53 AM
RevGTO's Avatar
Pontiacerator
With a 190k 95 4l60e you have to be concerned with the overall health of the transmission. GM didn't really start to get these units right until 96 and up. Perhaps, as stated above, what you're experiencing may be a rear end ratio factor. But you have to be thinking about the performance of the transmission in general - shift quality as well as shift timing, is there slippage, failure to engage gears, etc.
Old May 24, 2018 | 05:51 AM
Lee Cooper's Avatar
Only things of note trans wise is the 1-2 shift is super firm and the damn brake safety switch to shift out of park.
Old May 24, 2018 | 01:19 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
If it's really just downshifting one gear, then something isn't right. Original rear end ratio doesn't matter in this regard, it should be dropping lower than 3rd gear at 50mph if you go WOT. 2nd gear would be attainable at that speed regardless if it came with 2.73 (GU2) or 3.23 (GU5) gears originally.
But, it's possible that it is downshifting correctly and you're just experiencing the "dead spot" mentioned above. The best way to test this would be to manually put the selector in 3rd gear (D, not OD) at that speed and then go WOT, seeing if you get an additional downshift to 2nd gear and/or if it seems to pull any harder. This will give you a better indication of what's actually happening, and a comparison to what you might or might not be feeling when you do this from OD.
Someone may have installed a shift kit at some point then.
Old May 24, 2018 | 08:48 PM
Lee Cooper's Avatar
Thank you for the replies. The plan is to rebuild, both motor and trans but haven’t decided on a resto job or go mad for power. What’s a built 4L60E capable of handling safely?
Old May 25, 2018 | 06:36 AM
Jays_SSZ28's Avatar
It actually does matter.
It needs to be reprogrammed for the gear change. He said he put 3.73's in it, now the driveshaft rpm is higher compared to mph. upshifts and downshifts are controlled by mph and tps. The speedo would also be off, reading higher than vehicle speed.
Old May 25, 2018 | 01:55 PM
RPM WS6's Avatar
It wouldn't matter at all for 2.73 or 3.23. But, you're right about the OP having 3.73s - I missed that the first time around. However, I don't see where the OP specifies whether or not it's been reprogrammed. 2nd gear downshift could still be possible with 3.73s @50mph, but of course you're right that details of the tune will matter in this case.
Old May 25, 2018 | 11:37 PM
tug686spd's Avatar
From personal experience if the speedo hasn't been corrected for the gear change all the factory shift points will be fine where they are. The mph and rpm as far as the computer is concerned is still doing the same thing and matching up just the way it did before. If someone did try to correct the speedo and didn't fully go through tuning the tranny and just did the minimal changes to get part throttle decent then said the hell with the rest could be the problem.
Old May 26, 2018 | 08:22 AM
Jays_SSZ28's Avatar
You're right, the speedo will read exactly the same at any given rpm. The only problem is, the car isn't going that speed.
The computer shifts off mph which is calculated off the driveshaft (more specifically the output shaft. You swap from 2.73 to 3.73 your driveshaft is now going faster at every actual mph. At 60 mph with 25" tires and 2.73's in .7 overdrive the driveshaft rpm is 2201. With 3.73's it's 3007. Just with that gear swap it goes from being calibrated to 60mph in the example above to 81 mph.
It only seems the same because the speedo vs tach readings are the same.
I'll leave it at that. Kind of tired of wasting my time. It's fact not hearsay. It's not my opinion.
