4l60e pump rebuild kit
Old May 26, 2018 | 09:49 AM
jalfredprufrock's Avatar
Default 4l60e pump rebuild kit
Hi all....could someone tell me where I can get a pump rebuild kit for the 4l60e in my '95 GMC K1500 4x4. Having no luck finding one....that seems strange. And is my pump a 10 or 13 vane pump? jl
Old May 26, 2018 | 04:13 PM
Jays_SSZ28's Avatar
You should take your pump out and look at it before ordering parts. If the pump failed it usually damages the housing to the point of needing machine work with tools hardly no one has except huge transmission rebuild companies.
If it's damaged it might be better to get a rebuilt assembly, and if it's not you will know what parts to buy. '95 probably had a 10 vane but it doesn't matter, you can swap in a 13 vane and not notice a difference.
Old May 26, 2018 | 09:24 PM
PBA's Avatar
PBA
If it does not to be re-machined, then I can help you with everything that is needed here. If the pump needs to be re-machined, find a local machine that can do this if possible, otherwise use will need another pump to start with. The 1995 uses a 10 vane rotor and slide setup. DO NOT put a 13 vane rotor setup in a 10 vane pump. The 13 vane pump is completely different, not just vane count.
Old May 28, 2018 | 04:50 PM
built408's Avatar
Post some pics of the pump, this will help letting you know what you need.
The proper way to do it is to machine the cover and body. But most don't have the means to do that.
Old May 29, 2018 | 07:23 AM
MaroonMonsterLS1's Avatar
The porting on the slide is different, the rotors are interchangeable. Correct me if I'm wrong here.
So, a 13v slide needs to stay with a 13v pump housing, but you can mix and match the rotors. Even putting a 7v into a 13v slide if you want.
Old Jun 1, 2018 | 10:09 AM
I'm thinking getting a rebuilt pump is my best approach. Anyone suggest a good source?
Thanks for the replies...very helpful.
jl
Old Jun 2, 2018 | 06:40 PM
Will this fit my '95 4l60e? The description would say yes, but I wanted to confirm with you guys!
https://www.ebay.com/itm/700R4-4L60E...4AAOSwySlaRVP~
jl
Old Jun 2, 2018 | 07:06 PM
Jays_SSZ28's Avatar
jl
What if your pump housing is torn up?
If you need a pump it usually isn't perfect.
Old Jun 5, 2018 | 07:34 AM
PBA's Avatar
PBA
When using a 13V pump, you can change rotor count just use the 13V slide. Some units that I have helped with, we use the 10V or 7V rotor depending on horsepower and WOT rpm shift points. The 10V or 7V rotor is stronger, and rarely breaks.
Old Jun 5, 2018 | 05:13 PM
mrvedit's Avatar
Moderator
Your ebay link goes to the correct parts for a 10-vane pump internals kit.
As mentioned, post pics of the two halves where the pump rotor runs; it is likely worn after 23 years.
Old Jun 7, 2018 | 03:32 PM
This is exactly what I do. Most of my low hp unit 700r4 have a 10 vane in them so I put in a 13. Slightly smoother and the customer appreciates it. Then I save the 10 vane for higher hp stuff. The slight increase in volume and the absolute increase in strength is good.
I have 2 7 vane rotors on the shelf but haven't had a high enough rpm unit to necessitate them yet
Old Jun 15, 2018 | 07:17 PM
I'll post a few pics of the pump soon's I get the tranny out....Saturday the 16th with a bit of luck, i.e no snow
Thanks all for the helpful replies
