Teach me flexplates
Old May 28, 2018 | 04:40 PM
kendogg's Avatar
Default Teach me flexplates
Hi everybody. I have an interesting circumstance here. I'm doing an LS swap into a BMW, and using the BMW gearbox. Already have the adapter plate. The adapter plate setup sandwiches a stock automatic flexplate behind the custom flywheel so we can use the stock LS starter. The most I know about GM flexplates is they occasionally crank, and I get paid to replace it. For this application, would a stock flexplate be OK? Should I be looking at something aftermarket? If so, what? What makes the aftermarket one 'better'? Thanks in advance.
Old May 28, 2018 | 06:46 PM
8.Lug's Avatar
Unless you’re using an auto, it’s nothing more than a starter ring gear now. They crack when attached to a torque converter because they - wait for it - flex.
Old May 29, 2018 | 10:21 AM
Bspeck82's Avatar
If you are there always get a quality sfi plate and arp bolts.
