Need flexplate bolts longer than stock
Old Jul 9, 2018 | 04:22 PM
GrannySShifting's Avatar
Default Need flexplate bolts longer than stock
but not the ATI ones that come with their flexplate, the bolt head is too tall.
Thought I saw a stock style bolt that was longer than the OEM one at one point?
Old Jul 9, 2018 | 05:53 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
The bolt for flexplate to crank OR flexplate to convertor ?
What is the specs of the ATI bolts you speak of,thread dia,thread pitch,lenght under head,thickness(length) of head.
Old Jul 9, 2018 | 05:58 PM
sjsingle1's Avatar
i bought ARPs for for my new TCI....found out they were to short.....got some new ARPs 5mm longer
Old Jul 10, 2018 | 07:23 AM
MaroonMonsterLS1's Avatar
GM made 2 flexplate bolts. One short for use with dish flexplate and no spacer. And one long for use with the spacer. The long ones for use with spacer are P/N #19257940
Old Jul 10, 2018 | 09:56 AM
Flexplate to crank
The heads are too tall on these, and the factory threads are too short to use with ATI spacer/flexplate
Old Jul 10, 2018 | 01:34 PM
What do you mean the head is too tall? What are they contacting, the converter?
Old Jul 10, 2018 | 02:33 PM
Yes. We have measured .345" clearance on current design FTI 4L60e, not suure on their older converters what it was (they changed how they do their pilots) an older Circle D only have .260" I think it was clearly see ARM stamped into the converter itself when we took it apart LOL
Old Jul 10, 2018 | 05:01 PM
sjsingle1's Avatar
flex to crank bolts or flex to converter bolts ?
Old Jul 10, 2018 | 10:00 PM
Answerd above
Old Jul 11, 2018 | 03:53 AM
sjsingle1's Avatar
used ARPs there also....no problem on the length
