4L80 Tune / Nitrous Converter
Typically guys buy a triple disc so that they can eliminate the need for compromise.
To get a converter that is efficient on the big end, you typically sacrifice some stall speed and torque multiplication on the low end. And vice versa if you want the low end, you sacrifice the efficiency up top.
With a triple disc, you can get the low end, then get maximum efficiency up top by locking it up. I've personally not run a triple disc on my car (I've built for guys that run them) so I can't say any of this for sure...but maybe it's something to consider. If it were me, I would call and speak with someone on the phone from circle D and just go over everything again.
Also, use the input speed sensor on the 4l80e and compare that to the engine rpm to get converter slip.
Then compart the input speed vs output speed and see if there is any trans slip components.
Just to be sure.
Just to be sure.
Just to be sure.
Just to be sure.
on a 4l80e tcc slip is calculated the same way I told you to calculate converter slip.
Engine RPM vs Input speed sensor RPM
TCC slip is just calculated only when the tcc is locked
