Jakes Performance 4l80 Recal kit, dual feed
Old Jul 31, 2018 | 11:07 AM
Ws6ls's Avatar
Default Jakes Performance 4l80 Recal kit, dual feed
Im wondering if someone can clear something up to me, If I do the dual feed mod and the recal kit, do I still need to block of the part on the valve body?
Old Jul 31, 2018 | 06:55 PM
MIKE93SVT's Avatar
I did. never seen a situation where it was left out during the dual feed mod
Old Jul 31, 2018 | 07:02 PM
Ws6ls's Avatar
I cant find the right size cap to plug it up with, any idea where I could find one?
Old Aug 1, 2018 | 07:14 AM
MaroonMonsterLS1's Avatar
3/8 is the right size
555-115 dorman at any parts store. Might have to order them from a warehouse.
Yes you have indicated the correct hole to plug. Drive it in halfway before installing the center support...then drive it in further until it bottoms against the center support. I like a properly sized piece of brass best for this, but if you find a socket that fits that should work fine too
Old Aug 2, 2018 | 10:12 PM
brandon6.0's Avatar
if trans is apart could u tap it and thread a plug in? im working on dual feeding a th400 and was gonna try that. Heard u can plug the hole in the valve body as u have it marked OR the same hole in the actual center support.
Old Aug 3, 2018 | 07:00 AM
Cup plug. No need to tap and use a set screw in this location.
You often tap and use set screws to block the 2-3 accumulator and also to block the converter feed circuit. But that one you drill a hole in the center of the set screw to act as an orificed hole to control converter charge pressure
Old Aug 4, 2018 | 09:35 AM
Krom's Avatar
Jake's kit comes with a new separator plate...
The directions don't mention anything about blocking the hole I assumed its because that is done by the plate, but I haven't installed mine yet
Old Aug 7, 2018 | 01:01 PM
Jake's Performance's Avatar
Correct.
Don't over think it. Follow the instructions. It's really that simple.
