Dipstick hash mark - fluid amount
Old Aug 1, 2018 | 09:29 PM
Camaro223's Avatar
Default Dipstick hash mark - fluid amount
Hello,
I recently did a fluid and filter change in my trans.. And have a few questions.. Hopefully someone can help me out.
I added 5 quarts of fluid.. upon checking fluid level, it seems to be roughly 1/4 inch above the hot line/hole.
1 should I drain some out asap? Or is it ok to be over slightly?
2 Would it be correct to assume this is about half a quart over?
3 Do the dipstick hash marks represent 1 quart from low to full?
Thanks for any help in advance guys !
Old Aug 1, 2018 | 10:07 PM
98CayenneT/A's Avatar
Once you drive it for a bit it may drop a bit, even if it does not you are fine. Over filling a half quart to a full quart helps prevent fluid starvation during the 2-3 shift at wide open throttle. I always over fill mine. You are probably a good half quart over but not to over filled.
Old Aug 2, 2018 | 06:36 PM
Camaro223's Avatar
Interesting..How much is too much extra before the fluid gets aerated and becomes an issue out of curiosity?
​​​​​​Also, are the hash marks from high to low 1 quart?
Thanks again!
Old Aug 6, 2018 | 08:06 PM
performabuilt's Avatar
LS1Tech Sponsor
The dipsticks from my observation as well far from accurate, Ideally you want the level running to be equal to the pan rail but not above that to avoid aeration like a blender.
Being a little over full on the stick as mentioned can help avoid emptying the pan on shifts particularly the 2-3 shift however a good deep pan even from a truck will usually solve this also. We use the deep truck pan on all our units with the exceptions of the corvette and of course the Black edition gets a much deeper pan,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 6, 2018 | 09:35 PM
LS6427's Avatar
This takes a long time, but once you do it you will know exactly the amount of oil thats in your engine to a half qrt accuracy.
Next time you do an oil change....do it at your house and let it drain over night. Preferably with it slightly jacked up where it needs to be so its at an angle where ALL of the oil can drain out of the oil drain port over time. Don't let any stay in the oil pan.
Then the next day put the oil drain plug in and pour in 3 quarts right away. This should not show anything on the oil dipstick...BUT if it happens to show a tiny bit on the end than you know that means you have 3 qrts. Then pour in the 4th qrt. and wait about 20 minutes for it to settle into the pan. Put your dipstick in. Pull it out and with a file....mark the dipstick as 4. Then pour in the 5th qrt and wait 20 min. Then again...mark it as 5. Then pour in the last 1/2 qrt.....or the 6th qrt if you're one of those guys.....mark that as FULL.
You can even use a punch set to put the numbers 4 and 5 on the dipstick.
If you want to get ****.......make a mark inbetween 4 and 5 for 4 1/2 qrts.
DONE.
Old Aug 7, 2018 | 08:10 AM
biketopia's Avatar
DONE.
Well since the OP is asking about transmission fluid level, I'm sure marking the engine oil dip stick will certainly come in handy.
Old Aug 7, 2018 | 01:02 PM
gesto's Avatar
Ugh! So how do you accurately check the fluid level?
Old Aug 7, 2018 | 02:58 PM
01ssreda4's Avatar
I fill mine to full, then add an extra quart, then keep an eye for leaks and always ensure its over the hash marks when i check it. Works well.
Old Aug 8, 2018 | 06:49 AM
forcd ind's Avatar
If its a factory dip stick, and installed all the way in the trans, they are pretty accurate.
Best way to ck is with the pan off, dip stick installed, ck that the full mark is level to a
hair above the pan rail, but not below (I shoot for about 1/8 above). All of the hash mark should see fluid.
When I have had to mod a stick, I make a new mark where I want the fill mark.
Your results or opinions may vary, lol
Old Aug 8, 2018 | 07:30 PM
gesto's Avatar
Thanks!
