4L80E Leaking
Old Aug 6, 2018 | 01:11 AM
alextc's Avatar
Default 4L80E Leaking
Hello,
I've got a 1983 El Camino that I swapped a 5.3L and 2002 4L80E transmission into. It has the stock, but shortened driveshaft and a 4L80E yoke.
I've had a leak at the outermost seal that you can see from underneath the car. I recently replaced the seal, but am still having the same leak.
I wiped it clean before taking the picture, but the ATF fluid appears to be coming from the black lip of the seal that contacts the yoke.
I've googled and came across many ideas around what this could be or how to fix it, but LS1Tech has been my most reliable source of information.
Any help would be appreciated!
Old Aug 6, 2018 | 06:33 AM
Jays_SSZ28's Avatar
Theres no end cap (welch plug) in that yoke. Whether thats the cause or not, that will be the next leak.
Is the bushing sloppy?
Old Aug 6, 2018 | 06:41 AM
forcd ind's Avatar
Is it a new yoke? as said, bushing condition. Almost looks like the yoke has been sanded
on, not smooth. Some yokes used a pinhole in the plug in the back of the yoke to let air out,
but they used a seal to prevent oil loss.
Old Aug 6, 2018 | 10:53 AM
alextc's Avatar
So I purchased a new yoke and handed it off to the driveshaft shop when I had the driveshaft shortened. I can't say 100% that the new yoke was installed, but I'd like to think so.
I don't feel like there's much play in the bushing. I can check again to confirm though.
As far as the welch plug, is this the part I should be looking for?
https://www.ebay.com/itm/4L80E-TH400...-/261196700656
I might just install that before assuming anything else.
Old Aug 6, 2018 | 12:22 PM
Jays_SSZ28's Avatar
Thats not the part at all.
Your yoke should look like this, with or without the hole.
http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=1143317&stc=1&d=137709 3070
If it has a sleeve inside like this below you can have a small hole in it (vented yoke) If theres no sleeve you need no hole.
I've never messed with a welch plug in a yoke other than plugging the hole when needed, just not something that comes up often.
http://www.geocities.ws/crosley_az/700speed.jpg
This is a welch plug https://www.sustainablesupply.com/to...aju2-c1316032/
Old Aug 6, 2018 | 10:59 PM
alextc's Avatar
This is the best picture I could get of the back end of the yoke
Old Aug 7, 2018 | 06:44 AM
Jays_SSZ28's Avatar
Shouldn't be open like that.
Old Aug 7, 2018 | 10:18 AM
alextc's Avatar
Got it. Now I'm trying to figure out if it makes more sense to buy a new yoke or add the sleeve/cap to this one. I can't find much information on this topic.
