4L80E cooler line fittings
I need to replace the factory quick connect cooler line fittings in a ~2004 4L80E. NPSM fittings, long rear fitting has an o-ring while the front fitting has a tapered seat. What's the torque for installing these fittings into the case? Want to make sure I don't strip/break anything...
Hope this helps.
