4L60 pump alignment tool...
The pump to case bolt hole size looked real familiar, and it is, a 223 case drops right in with just enough taper to tighten it right up and finish with a band clamp.
If you do the pump before you load up the case you can loosely put the pump together and put it into the case upside down, then tighten the five pump bolts and it is aligned.
I prefer not to use the reverse case method. You can still misalign the pump when doing that. There’s just enough clearance that the halves can be off a tiny bit, while it won’t affect operation, it does make it harder to take the pump back out if you need to while adjusting clearances. Just my personal experience. I’ve built well over 50-60 of these units. The big worm drive clamp is the best and cheapest method I’ve found so far. FWIW
