Should I get my shift kit installed?
Yes...its good to use.
Tuning the trans to shift the way you want is a shitty way to do it imo. Sure, cranking up shift pressure adders will give you the feel you want...but all too often I've seen pressures cranked up, force motor tables goof'd with, and it causes just as much harm as good
It's a mixed bag...the shift kit is the right way to do it...so you could install shift kit and re-tune
but on the other hand if it's working...don't fix what's not broken. If it's holding the power and shifting fine then leaving it might be fine.
Have it installed.
Or leave it the way it is now.
The problem is, how many miles on it?
It's 20 years old. It's not unheard of to have the trans just give out at that age and 20 years of daily driving. BUT if a shift kit is put in, then thats the problem.
It could have 500k on it but once a shift kit is put in, thats the cause of failure.
Also you're not going to have them pull it out and install the clutch return springs that come in the HD2 kit.
Have it installed.
I have an HD2 kit without the springs in my s10 and rev it to 6500 a lot. Recently noticed my fluid looks burnt. It operates great though. I'm using Castrol TransMax and it looks dark and smells weird to begin with.
And I set it up with the 3-4 at .020 clearance.
I've always wondered if the springs did anything. It seems they delay the low speed shifts.
Just interested in what you think of these things.
I've seen the springs all "lay over" to one side and ruin things. It has happened once in a unit i've built and twice in units i've repaired that came from different builders. My solution has become to alternate the tapered end of the springs. One up...one down...one up...one down...and so on...But I still am not a huge fan of them.
The whole point of them is just like the return springs in any other clutch...to help resist centrifugal apply. I've found that despite my best efforts in sealing off any leak possible in the 3/4 clutch circuit...it's just not ever perfect. So I don't see any huge issues with centrifugal apply...The helper springs keep the clutches from dragging enough to keep me happy.
The trans has a mechanical barrier that the tune just can't overcome. That's why I personally prefer a properly installed shift kit (about 70% of an HD2) and using the computer to fine-tune shift feel.
Also...a tune can't solve all of the internal fluid bleed offs and leaks and it's can't magically create clutch capacity.
however...Like I said up above...if you are happy with how it shifts now...and you're stock or close to stock...then just drive it and leave it alone.
