Need a little help with my 4l60e!
Old 01-24-2019, 05:30 AM
Matt Brantley's Avatar
Default Need a little help with my 4l60e!
Okay guys here's the deal . I have a 2001 GMC 4x4 5.3 . My trans took a ****. Now I have a brand new Jasper 4l60 from a 1999 GMC 4x4 with the 5.7. Now correct me if I'm wrong but in order to mate the older trans to my 5.3 I need to order the GM spacer to make up the shorter crank in the LS and either buy the Unversial flex plate to bolt the 5.7 Torque Converter or simply oval out the round factory bolt holes in my existing flexplate because if I'm not mistaken the 5.3 Converter does not fit the input shaft on the 5.7 4l60 correct ? Other then the spacer and the flex plate the only other difference I'm seeing is 1 TOP bolt hole on the Bell housing . i already have my LS Tcase bolted to the older style trans.
Old 01-24-2019, 08:42 AM
LS1Tech Sponsor
performabuilt's Avatar
Sounds like you have it covered .
Frank
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 01-24-2019, 12:27 PM
Awesome ! I just wanted to make sure I had it correct . My spacer is in the mail I have my flywheel at work today measuring out the holes for the 5.7 Converter .
