4L60E to 4L80E....what tuning is required?
Old Jun 5, 2019 | 12:45 PM
stilealive's Avatar
I see what you mean. I just got an email today from Frost....yes, he confirmed that his harness (which I have) is all I need to make it all work. No segment swap to be done on the 98 PCM. He also said for $100 he will tune my 1998 PCM and it will operate like a factory 4L60E. So I'll be sending it to him and having my local guy install my 80E asap.
When I bought the harness I got confused that he also needed to do a segment swap in my 98 PCM.
Thanks....
Originally Posted by Hardtop Brian
I meant this plug n play harness Frost sells with the built in relay so you don't have to segment swap.
https://www.efi-performance.com/mobi....aspx?id=37539
LS engines didn't come in trucks until 99 year. I'm not sure about vans though.
I just read that 97-98 pcms are not segmented. Post is from 2014 though.
