What Broke?
Old Jun 3, 2019 | 07:32 AM
L33's Avatar
L33
Default What Broke?
1998 S10 4L60e with 65/70 upgrade, 3k stall, with 420HP 5.3 in front of it...
At the track, caught hard wheel hop shifting into second (auto shift in OVERDRIVE, I think it caught rev limiter before the shift)...
Hard grinding sounds and locked the back wheels up for a few feet, rolled out the 1/8 mile and returned to the pits, at about 30MPH on the slow down roll, it locked the tires again for a few feet...
First thought was broken pinion tooth in the rear end, but upon inspection the diff is still perfect.
I pulled the pan and filter and had a good amount of metal but didnt seem burnt so it seems like something physically broke.
Just curious what yall thought I broke. I could still drive it around the lot and drove it on and off the trailer, but I believe if it were to try for second gear something would break... Can you like blow clutches apart?? Planetary?? Sun Shell?
Its going to the shop but im just curious for now.
Old Jun 3, 2019 | 08:21 AM
98CayenneT/A's Avatar
Possibly low roller sprag/clutch
Old Jun 3, 2019 | 08:57 AM
Jays_SSZ28's Avatar
Is this a guessing game to see what forum member gets lucky? Then they will be thought of as being the smartest...
Old Jun 3, 2019 | 09:07 AM
L33's Avatar
L33
I like that idea lol
but I'm just curious what wheel hop would break internally.
Old Jun 3, 2019 | 10:55 AM
Jays_SSZ28's Avatar
The low roller, forward sprag, sunshell, front gear set, or rear gear set. Seeing how it still moves a little probably not a shaft.
Old Jun 3, 2019 | 12:22 PM
MaroonMonsterLS1's Avatar
Heres a thought...take it apart and tell people what broke...obviously its trashed so why bother guessing
Old Jun 3, 2019 | 12:45 PM
L33's Avatar
L33
Thanks for the help, I'll keep that in mind.
My apologies for trying to learn and plan. I'll just wait and keep everyone happy.
Old Jun 5, 2019 | 01:45 PM
" i think if it went in 2nd it would break"
why would you think that...did you try?
This is why forum guessing games are silly
Just take the thing apart and find out what broke.
What are you trying to learn and plan for? **** is broken...are you going to guess what part broke and order before you have it apart? If so, that's one of the funnier things i've read all day.
Old Jun 5, 2019 | 02:00 PM
L33's Avatar
L33
Cool story bro,
Sprag is busted, btw.
Last edited by L33; Jun 5, 2019 at 02:17 PM. Reason: Not lowering myself to the level of a douche
