4l80e shift solenoid plug
Hey guys I have a 4l80e with a full manual valve body conversion with zero electronics except for the converter lock up. So I've been having an issue with my 1-2 shift when the trans gets up to temperature the shift takes a second to happen and its lazy sometimes... I talked with a 80e builder at hughes performance and he said the shift solenoid is leaking or the linkage is off. So I checked the linkage and it's perfect, then looked for the shift solenoid to replace it and found theres a plug instead of a solenoid. And sure enough the o ring on the plug was garbage and the plug could just be wiggled and moved all around. I've tried looking everywhere for either a new plug/o ring but I havent had any luck and its driving me insane so I'm wondering if anyone knows where I can get the new parts or some other solution. Heres a picture of both solenoid A and B plugs
Who built the valve body with the plugs?
Have you reached out to them for a new one?
Also, if you need just the o ring, I would *assume* that it uses a standard solenoid o ring....any trans shop local to you should have 100 of those o rings just laying around. Ask for one
Gotta pick up the phone if you want a quick response from anybody worth their salt in this business.
It's usually the best way to get the info you want anyway...an email chain with 10 followup questions can be replaced with one phone call
