A-4 downshift lunge
Old Sep 5, 2019 | 12:43 PM
Tyler Dietzenbach's Avatar
Default A-4 downshift lunge
I have an A4 in my 1998 Z28. Bought the car with 25K on it, now have 46K on the car. Its done this ever since I bought it. When the car downshifts from 2nd to 1st gear the car jerks forward. At about 30K miles i replaced the u joints and it went away for about. 50 miles and came back. Every other shift in the car is picture perfect. The jerk feels like it comes from the rear. Like someone bumping into the car almost. If I put the car into neutral it does NOT happen. It DOES happen in both D and OD
Old Sep 5, 2019 | 05:08 PM
Jays_SSZ28's Avatar
Have you gotten under the car and inspected anything?
Old Sep 5, 2019 | 06:56 PM
Such as? I haven't really found anything by looking/ pulling on stuff.. but i don't really know what exactly to start with.
Old Sep 5, 2019 | 09:58 PM
Jays_SSZ28's Avatar
If you can't find a problem you're most likely not going to be able to fix a problem.
Sure someone can point to a part and say replace this or that and you might be able to do that, but how does that get done over the internet?
If I say replace the lower control arm bushings and you do it but it doesn't fix the problem and you're out the time and money are you going to be happy with that?
You're probably better off having someone look at it.
Old Sep 6, 2019 | 08:26 AM
bleepster's Avatar
i think hes trying to ask "if it was your car - where would you look?" I dont think he asking for YOU to tell him how to FIX it. Hes simply asking where to start.
Old Sep 6, 2019 | 08:29 AM
I wouldn't mind tracking down the problem by replacing things. I'm not a total car idiot, I have some capabilities. I would like some suggestions and where to start. Could it be the torque arm? Drivetrain slack? Transmission mount? Im looking for things like...What to grab onto and check for play ect. Again, just looking for places to start my search.
Thanks.
Thanks.
Wow. Haha. Yes. Thank you. Exactly that
Old Sep 6, 2019 | 08:49 AM
TA_Freak's Avatar
I would start by considering the possibilities. Transmission mount .... do you get a vibration? Also you mentioned u-joint replacement in the past cleared it up (for 50 miles). That's a huge clue to me. You should be able to get under it and pry and inspect those things.
Old Sep 6, 2019 | 09:11 AM
I dont have any vibrations. What's the best way to check the u joints? And why would they fail so quickly?
Old Sep 6, 2019 | 09:50 AM
TA_Freak's Avatar
The only way that I can see that a u-joint would fail so quickly would be installation error. Did you do the replacements? I can't imagine how it would happen, but it's interesting that the problem cleared up right after replacing them. But ..... it could well be the transmission since it's only a downshift from 2 to 1. Every now and then mine will clunk when it's "hunting" (I think that's what it's called) while I'm slowing down immediately after accelerating. It's always done that and I guess that's the nature of the beast.
Old Sep 6, 2019 | 10:25 AM
MaroonMonsterLS1's Avatar
the car jerks forward...or your head jerks forward?
if your head jerks forward (like if you were to tap the brakes) that would be a much different diagnosis than if you said the car lunges forward (which would plant you back in your seat)
Old Sep 6, 2019 | 11:38 AM
That's a very interesting discussion piece. It is more like a jerk without a sound while coming to a stop. Literally the second before it stops and shifts into 1. Its the car itself lunging forward. The RPMs don't move at all when it happens.
Old Sep 6, 2019 | 12:49 PM
low roller sprag catching.
very common in th350's...same part in 700r4 and 4l60e's
it's likely wallered out the case a little bit.
Old Sep 6, 2019 | 09:16 PM
Didnt really know that was a thing.
I just checked both ends of the torque arm. No play. Same with both ends of the driveshaft.
Old Sep 6, 2019 | 09:19 PM
They were installed by a very reliable mechanic and I helped put them in. Quite honestly 50 miles was an estimate. It was 7 years ago or so. It quit doing it for at least a day and then it was back. Yes. The hunting issue Is common. I've had it happen before. A lot different feeling though.
Old Sep 6, 2019 | 09:46 PM
So you can actually hear a clunk in the rear when this happens. I guess i became so accustomed to it over the years I just didn't notice it anymore. I also double checked and the car definitely jerks slightly forward and clunks in the rear. Just to clarify it does ever so slightly make your head go BACK.
Old Sep 7, 2019 | 02:05 AM
vorteciroc's Avatar
Interesting...
I am just thinking back now... as I almost never see any THM350 units in my shop any more...
I recall two or three revisions to the low/ reverse one-way roller clutch and outer race assembly going from 350 to 700 and to 60E.
-One time the rollers had their diameter increased with slightly larger retention springs.
-Another time the height of the one-way roller clutch was increase to take advantage of the full height of the outer race.
If I recall correctly; the only time I experience problems with these would be when some dumb-**** design trans-brake gets added to a 350/ 700/ 60E.
I have had my guys replace these on every rebuild for the longest time... but are you seeing issues or torque related failures in your shop?
Old Sep 7, 2019 | 06:55 AM
bbond105's Avatar
I think MaroonMonster is referring to how the low roller clutch outer race will wear the splines in the case and the low roller clutch outer race will twist in the case causing a clunk on down shift.
Old Sep 7, 2019 | 07:42 AM
Jays_SSZ28's Avatar
Is this low roller problem going to happen at 46,000 miles? I don't think so, unless the car has been neutral dropped a few times. I've had that problem with a th350 that I rebuilt for a guy I worked with several years ago. The low roller broke.
I had at least 50 low rollers in buckets because a transmission hard parts supplier needed his building emptied out and let me take whatever I wanted. I looked at every one of those low rollers and they all looked as good as new, was trying to figure out why the one broke. Later I found out the guy had been neutral dropping it.
So this car and all of its major parts have 46,000 miles? If that's true there's more to this story. I have an '02 SS with 54,000 miles.....with a '99 4L60E built from a core that had 250,000 on it because I once converted the car to a six speed and went back to an automatic. It has no problems.
If I had to make a wild guess with what's going on I'd look at the idle on this car. The way it's described put this problem right where the idle transitions happen in the tuning.
I can't go out and drive either of my two because they have high stall converters (which change the feel of coming to as stop) and all the little quirks have long been tuned out, like way back when they were stock.
So what kind of life has this car seen in it's 46,000 miles? I doubt that will be answered. Maybe the transmission needs to be pulled, because now there's a direction to go (although I thinks it's the wrong one).
