Multiple 4l80e pressure control solenoids failures
I put a 4l80E in my truck and have it wired for full manual shift. I have had 2 pressure control solenoids fail back to back. Can anyone help me out with what might be causing this?
Each solenoid fails after the first drive. This morning I drove the truck 15 miles to work and the previous time it failed after about a 5 mile drive. Each time the transmission is shifting fine until I shut it off and let it sit for a few minutes. Go to fire it back up and drive off and no forward gears. I can unplug the harness and it will default to second gear.
Wiring setup: Pins N-R-A together and tape into the harness.
Pins P-B together and tape into the harness.
Supply switched power to pin E to power up the transmission solenoids.
Supply ground to pin S to control lock up.
To put this simply; the pressure control solenoid is doing the opposite.
The pump creates the line pressure, and the pressure control solenoid more or less bleeds off the line pressure.
The pressure control solenoid controls how much the line pressure is reduced.
The EPC needs a current (amperage) to pulse/ hold its valve open to lower the line pressure.
The pressure control solenoid does not need a current to maintain line pressure.
More current = Lower line pressure
Less current = Higher line pressure
No current = Maintained line pressure
Just as Mr. Maroony Da Monsta said:
The EPC could (resistance wise) be good or bad... It would make no difference in the line pressure produced.
When wiring the valve-body control solenoids as you state you have... the EPC serves no purpose other then to prevent a line pressure circuit leak.
So I was able to get the truck back to my house today. The pressure control solenoid is not bad as I had thought previously. I just assumed it was since the first time I lost all forward gears I checked it and found that it was bad. I then replaced it, put the pan back on, filled it with fluid and it worked. I didn't know that the transmission would function fine once it cooled off as I never checked that when I had the issue the first time. So today I put it on jack stands and the transmission worked flawlessly. Ran it through all 4 gears and it had plenty of power to push through the brakes.
Cold pressure readings in gear no brake applied.
P-155 PSI
R-175 PSI
N-150 PSI
4-150 PSI
3-150 PSI
2-140 PSI
1-140 PSI
Let the the truck run in 4th gear for 30 minutes at 1500 rpm. Shut off the motor waited 5 minutes and started it back up. Took pressure readings in all gears and it was 100 psi across the board except for reverse and that was 140 psi.
Thoughts? I was planning to take the truck to the strip for the first time next weekend so If at all possible id like to get it back up and running ASAP.
Thank you all for the help.
Accelerated pump wear occurs with maintained max line (usually it won't make a pump **** the bed in the amount of time you've had yours running)
cracking the case is a byproduct of how you accomplished your manual control...you (as well as many others) don't account for the extreme pressure in reverse...we're talking 2x what max line is in other gear ranges...add that to a channel casting that has probably 10-12 square inches of surface along its entirety...and you're looking at alooooot of stress...you wouldn't be the first guy to crack the case in this area.
I'm not 100% those are your issues...but they're on the list of possibilities.
Simpler issues would be worn PR/Boost...crappy AFL...etc
Thank you for the input. I did these modifications prior to making the transmission manual shift so hopefully this takes cracking the case out of the picture. I am going to pull the transmission this evening and take the pump out for inspection.
AFL bore would still be suspect
Pump is suspect
clogged filter is possible
low fluid level
etc etc
I'd start with a pan drop and VB vacuum test along with visual inspection of the case
pump after that if it all checks out
Pump is suspect
low fluid level
etc etc
