Built 4l65e vs boost
Old Nov 2, 2019 | 08:34 PM
  #41
Kfxguy's Avatar
First... Thank you for the insult ;-)
I do not feel that you are a fool. Should I have; I would just say it.
On the contrary... You usually seem to grasp everything we discuss. So again; I do not think you as a fool.
Now in regard to the use of the over-drive gear range:
-Yes, there are plenty of builders who do not build their transmissions to handle power in over-drive (I feel this is a big mistake).
-Yes, the over-drive gear range is not intended to be used for racing...
However, that it is not for reasons pertaining to power handling...
It is because the over-drive gear range puts the engine at a massive disadvantage in terms of gearing/ gear multiplication.
Trying to accelerate the engine at low RPM in over-drive can be extremely taxing on the engine...
Particularly the connecting rods and can be a bad idea in certain situations.
The same thing goes for a T-56/ TR6060 six speed manual transmission with it's double over-drive gear ranges.
Knowing the engine and transmission inside and out is always a good idea to try and make the lives of such, as long as possible.
wasn’t trying to insult you by any means....if I did, wasn’t my intent. Maybe I put that the wrong way...my bad.
i always make efforts to make 4th hold as much as possible. But my car has around 700hp and I just think it’s just too much of a load everything shifting to OD full throttle. Just my strong belief.
Old Nov 2, 2019 | 09:27 PM
  #42
Jays_SSZ28's Avatar
You know the stock fourth apply piston has slighlty more surface area than the corvette servo. And theres aftermarket which should be used when running a 600 hp trans with a 700 hp engine.
Your problem is you're stuck on this 700hp ****. Not everyone is running at the limit of their transmissions abilities. You need to step outside the box because you got lost in it and can't find your way out.
Old Nov 2, 2019 | 10:40 PM
  #43
Kfxguy's Avatar
o look, if someone had 400hp or even 500hp and the Trans was built pretty decent, then yea. You could do some Od runs full throttle. But if I recall, this flocking thread is about a boosted motor and a 4l60. Not too many 400hp or even just 500hp boosted ls motors are running around. The norm seems to be greater than that. But whatever. I’m getting bored with this back and forth banter. Do whatever the flock you wanna do. I’m out.
Old Nov 3, 2019 | 12:02 AM
  #44
Jays_SSZ28's Avatar
It's about time you ran out of bullshit to push at me. You figured out I'm not buying it. It's not all about 700hp 4L60E's.
Old Nov 3, 2019 | 12:42 AM
  #45
Kfxguy's Avatar
It’s bullshit that I say it’s a bad idea to shift into overdrive at full throttle with a boosted build (that’s what this ******* thread is about if you read the title) and think it’s going to live? You’re either drunk, delusional or just plain ignorant. You don’t have to buy **** buddy, I ain’t trying to sell you a damn thing. I’m a 4l60e “fanboy”, but I’m not dumb. I know it limitations. And the OP asked if it would hold up in a 4000lb truck behind a boosted motor. And somehow we go on the subject of shifting to overdrive with it.....In a boosted 4000lb truck.....not a good idea no matter who built it and no matter what you say. Period. Buy it. Not buy it. I don’t **** a give.
go back and read post number 1. Maybe you’ll get it. Maybe you won’t. He stated 700-800hp. So I’m not so sure what the confusion is. Smh.
Old Nov 3, 2019 | 06:04 AM
  #46
Jays_SSZ28's Avatar
I figured you'd crutch it with your torque management, I mean **** put 98% on the 3-4 shift she'll be fine. Why not? It'll bend the 3-4 basket in 4th but not third?
Thats awesome, you typed SMH. What Are you 13....
Old Nov 3, 2019 | 06:09 AM
  #47
ddnspider's Avatar
... You need to step outside the box because you got lost in it and can't find your way out.
Holy pot meet kettle. Says the guy who can't get out of his own way that torque management can save a transmission.
Old Nov 3, 2019 | 06:18 AM
  #48
Jays_SSZ28's Avatar
Hey I'm not using it. But how is someone going to say too much power will kill a 4L60E BUT DON'T YOU GET RID OF TM!!!!!
So if thats the case HOLY POT MEET KETTLE, how does the guy who preaches TM saves transmissions going to go on and on about how a 3-4 shift will kill it......
If too much power can kill it, take your 700hp engine and choke it down to 250hp on the shifts with TM since it's almost 2020 and we have that technology.
Old Nov 3, 2019 | 06:24 AM
  #49
ddnspider's Avatar
This is the first time I've seen people say they build 4l60es to hold WOT in 4th. Is this for half mile racing? Most people kill their trans during the shift...hence TM helping. I believe Kfxguy is saying that it's not only the shift that'll kill it, it's that 4th won't hold while it's in gear. I don't build 4l60s just haven't broken one so you guys can battle about whether or not 4th can hold at WOT.
Old Nov 3, 2019 | 06:38 AM
  #50
Jays_SSZ28's Avatar
It's the application. He has a transmission thats barely holding on and he knows it so he's all defensive about it, and yet thinks he pulled off a miracle because it's living without the power "turned up"
And here we've got someone else wanting to **** money away on another one.
Thats not what I do. If I have an 800 hp vehicle I'm building a 1000 hp transmission for it.
The TM fans must agree, if you've got a 600 hp transmission behind a 800hp engine, just choke it down with TM.
Makes no sense to me but whatever, it ain't my money and it won't be my car on the side of the road or in the middle of the track, or running ONLY 11's with 800 hp.
Old Nov 3, 2019 | 06:41 AM
  #51
ddnspider's Avatar
I agree with over building.....but I am a TM fan because A) the transmission cost me nothing and owes me nothing and B)the negligible ET gain for a real street car isn't worth the wear and tear on the trans by removing all TM. Just different strokes for different folks.
Old Nov 3, 2019 | 11:15 AM
  #52
Kfxguy's Avatar
you’re funny. I only pull 2-3 degrees timing on my shift. I don’t do it just tonsave my transmission either. I mainly do it because the boost spikes on the shift and sometimes it shows some spark knock. And it takes the shock off of everything.
it’s been said before, but I guess. GM is stupid too, right? They do the same thing on all their vehicles. You think they might know something you don’t? O let me guess, you know better than GM too? I’d rather pull a couple degrees of timing than pull my trans out every 6 months anyway. Besides, when I went to the track, I disabled tm and it didn’t go any faster. I thought it was holding me back. But it wasn’t. So I’m not sure what you have going on up there in your hard *** head, but I can’t fix it for you. What about the hellcat and demon. You don’t think they have tq management? The demon is the fastest production car right now.....doesn’t seem to be hurting it. And look at the z06 vette. It’s got it too.
Old Nov 3, 2019 | 10:23 PM
  #53
PBA's Avatar
PBA
I have built many transmissions and customers using my kits that can make a WOT 3-4 shift and live when using the Sonnax 4th apply servo. And you can run a lot of Nitrous, "if" you use a window switch to shut the Nitrous off during the shifts. This is pretty much the same as using Torque Management. Once in gear the 3-4 clutches and or 2-4 band applied (they now are acting as a "static" clutch or band) can hold a lot more torque, as they are fully applied. It is always the shift that breaks or wears the clutches and band on the shifts. Torque management is one of the biggest reasons for the increased longevity of the 4L60E transmission.
Old Nov 4, 2019 | 12:13 AM
  #54
Kfxguy's Avatar
o no, you better watch what you say about tq management....the genius above will call you an idiot for using it. Lmao.
Old Nov 4, 2019 | 07:15 AM
  #55
MaroonMonsterLS1's Avatar
I tell customers not to do WOT pulls in OD because I use the sonnax HD2-3 shift valve...which applies the overruns in D3 shifter position and I think that's a benefit to help support the sprag when racing.
If they want to do 140mph+...go ahead and click it into overdrive what do I care. As long as the band can hold, everything else will be fine.
Old Nov 4, 2019 | 08:35 AM
  #56
AnnivSS's Avatar
That would mean to me; that your transmission builder has no confidence in their product/ service.
...And that is truly sad!
If a builder is going to offer an over-drive transmission this way... Why bother, and just go with a 3-speed unit (THM400 or other).
Sorry I forgot to mention that I was on a bone stock transmission at the time.
Old Nov 4, 2019 | 08:49 AM
  #57
neblackshirts's Avatar
Pretty sure this is the same advise you'd get from Performa and Finish Line Transmissions on the 4l65E. I have a 4l65e level 5 from Finish Line and talked to them after breaking a reverse sprag and on the rebuild was discussed to run in D because of reasons stated it applies the overruns takes pressure off the weak sprags but cruising and highway OD is good. Don't quote me exactly as I'm not any Transmission expert.
As others have said it's been shown that a lot of guys have run with success a 4l60e with lots of power, look at Performa, RPM, and Finish Line they have lots of fast guys running these transmissions. It can be done, but if it was my money on a heavy turbo build want OD 4l80e don't need OD Turbo400. Could you still burn up a 80e or a 400? Yeah if tune is shitty nothing will last very long.
Old Nov 4, 2019 | 09:34 AM
  #58
Game ova's Avatar
See, that's the thing about the Th400. It couldn't care less about the tune, or "shift timing". It flat out works, no special voodoo, or dances needed.
Old Nov 4, 2019 | 09:45 AM
  #59
ddnspider's Avatar
And A) requires you installing a completely different transmission than what's in the car, B) lose overdrive, and C) requires a conversion or adapter to get speedo. A 4l60e isn't stronger than a TH400, it's just more convenient for some.
Old Nov 4, 2019 | 09:48 AM
  #60
Jays_SSZ28's Avatar
Lets build a 1984 camaro with a turbo'd 350 and a 700R4. Stock engine, stock transmission (built for the power obviously)
We can build the 700 to 4L79 specs.
NOW, how do we utilize torque management? How do we make the transmission live. Hmm, I bet you have nothing for that.
