Help with torque converter or tans
Old Feb 16, 2020 | 07:53 PM
91 Z28's Avatar
Originally Posted by Justwannagofast
Yah ima try the Fitech I guess all I need is lil harness extension to my system so ima go to the shop and pick up one they are local in riverside
well I think ima save money this way I paid 300 for trans it was out of his wrecked car plus now I can put my funds to a good converter witch is a new battle for me lol
but ima call yank I think this week see what they suggest I use with my set up then I should be on the road FINALLY
I got a circle D. Awesome converter
Attached Thumbnails Help with torque converter or tans-20190718_180610.jpg   Help with torque converter or tans-20190718_110137-1.jpg
Old Feb 16, 2020 | 08:20 PM
vorteciroc's Avatar
Before you contact Yank, I would try first talking to FTI Performance for a torque converter.
I highly recommend their products and service.
My contract/ agreement with PTC is up; I also dropped ATI... I am keeping Neal Chance, however I may pick up FTI...
Should we be able to make an agreement. If not I am going to try Ultimate Converter Concepts.
FTI Performance torque converters are active and supportive on our message board.
If they do not jump-in and say hello, give them a try.
FTI Performance: 866-726-8358 or FTIPERFORMANCE.com
Old Feb 17, 2020 | 11:10 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Ask for Dalton or shoot me a PM. I'm here to help.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Feb 17, 2020 | 08:03 PM
Justwannagofast's Avatar
Ok maybe ill check them out because yank doesn’t really have a page I can find
that circle D does look mean how’s it treating you
ok Dalton ill give you call tomorrow so you can see what is best for me
Old Feb 17, 2020 | 10:11 PM
vorteciroc's Avatar
You are in good hands!
Old Mar 30, 2020 | 09:29 PM
So I’m back guys I put the trans in new torque converter
I’m still getting shaking and car wont accelerate
Old Mar 30, 2020 | 09:39 PM
91 Z28's Avatar
Driveshaft length is right?? Trans mount okay? U joints?? Is the harness put in the right way??
Old Mar 30, 2020 | 10:34 PM
So same drive shaft same length as 700r4
trans mount use same one but welded no tab to fit and got the angles off tremec app
yes wiring is right everything I got was labeled
so I smashed gas well holding break and they wont spin
Old Mar 30, 2020 | 10:35 PM
91 Z28's Avatar
Fluid level okay??
Old Mar 30, 2020 | 10:41 PM
Transmission was drop pan and I put about 6 quarts should I put more hard to read level with Lokar dip stick says full when engine is hot
Old Mar 30, 2020 | 10:49 PM
vorteciroc's Avatar
The dip-stick "Full Level" is often unreliable...
The only way to know for sure is to remove the oil-pan, look up into the transmission at the dip-stick and compare the "Full Mark" to the flange for the oil-pan.
The "Full Mark" should be at least level with the oil-pan flange or higher; up to an 1/8" higher.
Take a bright colored paint-marker and mark the dip-stick at the actual "Full Level" if not coinciding with the production mark.
Old Mar 30, 2020 | 10:58 PM
  #32
I can try that tomorrow if I remember I felt like is went down past the flange I wish I would of marked it
if low would that cause my issues
I felt like I was getting lil more response in reverse drive just has no power
Old Mar 31, 2020 | 12:38 AM
  #33
vorteciroc's Avatar
If you are referring to this:
Than NO; slightly low ATF level should not cause shaking...
Installing the torque-converter dry/ empty of ATF can cause some real damage and cause shaking.
Did you poor ATF directly into the torque-converter before installing it onto the transmission stator-support tube and turbine-shaft?
Shaking could be from rear wheels/tires. rear suspension/ incorrect geometry of rear control arms, incorrect drive-shaft angles/ Universal-joint issues, rear spring/ shock issues, body/ frame issues or power-train mount issues... ETC.
If there is no shaking; however there is lack of power... then we need more information.
When the vehicle does not accelerate, does the engine rev-up or does the engine lag with the rest of the power-train?
Old Mar 31, 2020 | 11:43 AM
  #34
So I poured whole quote of atf inside converter think I’m good there
there’s slight shaking when I hit gas
I’m getting no power to rear wheels car wont go past 5 to 10 mph when I rev engine feel like it hangs
I haven’t messed with any of suspension or wheels car rolled fine before 2 years ago
possible driveshaft angle I got to 1.8 angle
Old Mar 31, 2020 | 11:59 AM
  #35
Default My tune don’t know if well help
Old Mar 31, 2020 | 07:11 PM
  #36
I feel like it my rear end is not responding to the rpm vwerrry sluggish
Old Mar 31, 2020 | 07:17 PM
  #37
91 Z28's Avatar
Is your parking brake on?? How about the master cylinder, is it still good?? If your MC is shot your brakes could be locking up
Old Mar 31, 2020 | 07:53 PM
  #38
Parking break is released
not really sure about the break system its all Stock
i do have one of the biggest air ports off my intake going to the break booster
  #39
wheels spin freely when I have up in air
Old Apr 1, 2020 | 02:00 PM
  #40
LS1Tech Sponsor
Can you log what the vehicle is doing when it is shaking and limiting speed? I'm sure someone much more well versed in LS tuning than myself will see something that could lead to a fix.
__________________
1-866-726-8358
FTIPerformance.com
