Help with torque converter or tans
Old Apr 1, 2020 | 06:24 PM
  #41
vorteciroc's Avatar
When the vehicle does not accelerate, does the engine rev-up or does the engine lag with the rest of the power-train?
Originally Posted by Justwannagofast
there’s slight shaking when I hit gas
I’m getting no power to rear wheels car wont go past 5 to 10 mph when I rev engine feel like it hangs
So to me it sounds like you are trying to say that..
The engine is not revving-up when you try to accelerate, and the entire power-train is bogged-down and shaking.
If I understood you correctly about the engine not revving-up under a load... I am leaning towards an engine problem.
You might want to start a thread in the appropriate engine forum...
Old Apr 1, 2020 | 07:33 PM
  #42
91 Z28's Avatar
Post a video
Old Apr 2, 2020 | 03:11 PM
  #43
Justwannagofast's Avatar
Ok ima try and post a video seems like my reverse gbetting a response but still lil vibration
engine revs up maybe still a trans problem ?
Old Apr 2, 2020 | 03:16 PM
  #44
I don’t know how to post video on here maybe ill try start engine form sorry for all the confusion
Old Apr 2, 2020 | 04:47 PM
  #45
Default Video
I can only post few seconds here’s a lil what’s going on when I hit the gas
File Type: mov
Old Apr 2, 2020 | 04:51 PM
  #46
Default Video
Here’s a lil more
File Type: mov
Old Apr 2, 2020 | 11:25 PM
  #47
91 Z28's Avatar
Here’s a lil more
Make a decent video, put it on YouTube then put the link here. Car looks sweet
Old Apr 3, 2020 | 12:34 AM
  #48
Ok no will right now
and thank you
Old Apr 3, 2020 | 01:02 AM
  #49
I should 4l60e logging too
Old Apr 3, 2020 | 02:57 PM
  #50
Default More videos
Posted couple more videos of the tune and how there’s no power to rear end I’m getting vibration by my feet n torque converter area
Old Apr 3, 2020 | 05:53 PM
  #51
Ok did pressure test on trans today
60psi in park
170psi drive
220-225 reverse
I posted a video to on YouTube
mrjustwannagofast
Old Apr 3, 2020 | 06:02 PM
  #52
So when I hit gas in drive psi dropped all the way to 60psi and stayed there but reverse stayed up
and my car made a new noise today you can here in video when I slam the shifter in to park from drive I hear air blow out
Old Apr 3, 2020 | 06:07 PM
  #53
vorteciroc's Avatar
If those line pressure readings are at an idle...
Than they are high!
Old Apr 3, 2020 | 06:32 PM
  #54
Tyler Dietzenbach's Avatar
I highly suggest you just trash the other thread you started.
Old Apr 3, 2020 | 06:56 PM
  #55
Yes from the first video everything was from idle
second video I hit gas
Old Apr 3, 2020 | 06:57 PM
  #56
Does it mean bad transmission bad pump I cant get a vvs reading on my Fitech computer
Old Apr 3, 2020 | 07:17 PM
  #57
bbond105's Avatar
Did you check to see if the flex plate is broken?
Old Apr 3, 2020 | 07:24 PM
  #58
Default New
I mean when I installed it I did and it’s brand new straight from eBay lol so don’t know if it’s out of balanced or broke
Old Apr 3, 2020 | 08:09 PM
  #59
I never touched bottom end of endings could my crank be out of balance its all stock
Old Apr 4, 2020 | 07:00 PM
  #60
Default Transmission pan
Pulled pan
