4L60E help
Old May 2, 2020 | 02:11 PM
Keith Hess's Avatar
Default 4L60E help
my 2000 Silverado will not go tnto 3-4 gear,So here is what i have done,bought 3 different trans ,1 different Transfer case, new speed sensors, checked all fuses , all are good, Same Results. now im going after ignition harness, no speedo, no tach, gauges dont work.anything will be helpfull and apriciated. 2000 silerado vortech edngine,4L60E Thank You.
Old May 2, 2020 | 02:58 PM
Kfxguy's Avatar
Throttle position sensor? . gound. pin in the man trans harness bent/broken/pushed out.
check engine light on? shifts fine from 1-2? or does it hold out?
Old May 2, 2020 | 03:41 PM
B52bombardier1's Avatar
Sounds like 3-4 clutches are gone. Do you see a DTC code for "P1870"?
Rick
Old May 2, 2020 | 05:39 PM
mrvedit's Avatar
Moderator
What happens when it should shift into 3rd? Does it stay in 2nd and just rev higher and higher?
Or does it feel like it shifted into neutral?
Put a scanner on it to look for codes.
Old May 3, 2020 | 11:25 AM
Keith Hess's Avatar
thanks guys fo your feedback ,its strong in 1st 2nd no hesitation, when going to 3rd it acts like it hits neutural , when i put this transmission in ,there was no sign or smell that would indicate burned anything, all three transmission ive installed do the exact same thing ,ive also tried a different transfer case.,im thinking it has to be electrical issue, i will see if i can get a code to pop up, and get back to you, I really dont know what to check on electrical side, because i dont know what runs the transmission, and my speedometer and gear select display and tachometer all went out at the same time, they say no speedo no shift , thank you for your response, i appriciate it.
Old May 3, 2020 | 11:48 AM
Kfxguy's Avatar
If it feels like it hits neutral, it sounds like the clutches are gone. Would be quite odd to have three bad units but 3-4 clutches is a very common issue. I would think after the second trans, you would have done it right and had it rebuilt instead of keep putting junk yard units in. I’d never do that, you have no idea of the history or condition of it. Like a roll of the dice.
Old May 3, 2020 | 06:10 PM
Yea, if you have no speedometer indication, it won't shift. Either bad VSS or bad wire from it.
Rick
Old May 3, 2020 | 06:39 PM
vorteciroc's Avatar
Rick
You hit the nail on the head!
VSS should be in the transfer case...
Making 3 different transmissions all act the same.
Old May 3, 2020 | 06:41 PM
vorteciroc's Avatar
Any of those different transmissions may have other problems...
But the VSS or VSS circuits are the most likely major issue.
