4l80e yoke
Old May 17, 2020 | 04:21 PM
71cutlass442's Avatar
Default 4l80e yoke
Hello everyone, I have this 4L80e trans that I picked up from a buddy and I’m trying to find a yoke for it. It’s a newer style trans with the cooler lines spaced out but doesn’t have the top bolt hole. From what I’ve gathered, a 32 spline th400 yoke is what I’m looking for but there’s so many. Vented/Non vented, Counter bored/Non Counter bored, Long shaft/Short shaft etc. Due to the metal sleeve, I can’t tell if there’s an o ring near the base of the output shaft. I’ve included some pictures hoping someone can lead me to a part number for the correct yoke for my application. I don’t want to have to cut or drill anything. Ls3/4L80e combo into a 71 442. Also, where can I find another rubber boot? As you can see mine is pretty torn up. Thanks in advance.
Old May 18, 2020 | 07:23 AM
MaroonMonsterLS1's Avatar
Long-Full spline (not counterbored) non-vented.
Since you have that cup and o ring you technically could use a vented...but there is no need or reason to.
Spicer 3-3-5551X would be fine. 1350 u joint.
Old May 18, 2020 | 07:44 AM
5.7stroker's Avatar
I plan to run a Fully Splined Output Shaft & a Fully Splined Slip Yoke regardless of what the 4L80E that I buy comes with as I will replace the output shaft with part number 24204289.
Counterbored Yokes that are for use on Bolt-on Yoke Output Shafts have a tendency wobble around & cause vibrations, Especially on 4th Gen F-Bodies.
I plan to run T3-35571HP Yoke with the full spline output shaft 24204289
Old May 18, 2020 | 08:16 AM
That 24204289 is the output shaft he has
The cup around the shaft is just to seal a vented yoke. It was an easy way for GM to keep yoke consistency regardless of shaft.
The spicer number will work...the T3-35571HP will also work. They're virtually identical measurements
Old May 18, 2020 | 02:35 PM
Are you sure it doesn’t have to be vented? There was another thread where a guy had an 80e like mine and when he tried to slide the yoke in he couldn’t get it to seat. I believe he drilled a hole to make it work but I don’t want to do that if I can avoid it. Is there a part number for a vented one?? Below is his video.
Old May 18, 2020 | 04:19 PM
BigBlackCamaro's Avatar
The guy in the video should just put the yoke on the driveshaft and install it. During normal operation the yoke travel is what 3/8"
It's not going to hurt a thing to have some air compressing inside that sleeve.
FWIW the sleeve can be removed and not used and it won't leak with a non vented yoke.
Old May 18, 2020 | 05:03 PM
truckdoug's Avatar
you can leave the sleeve on, just remove the oring if the air cushion bothers you
Old May 18, 2020 | 05:23 PM
it is just an air cushion. won't hurt a thing.
I prefer non vented in the case that the o-ring inside there ever goes bad or shrinks etc etc you don't have a big leak on your hands.
If you want vented to eliminate the air cushion and you want to run that internal cup...perfectly fine also
Old May 18, 2020 | 09:47 PM
Ok spicer for the win. I’ll be ordering one in the morning but now my concern is the image. It appears to be milled on the end. Should I be concerned about that? The eBay/Amazon image doesn’t show a milled end nor does it have 208 transfer case in its description.
Old May 18, 2020 | 11:57 PM
vorteciroc's Avatar
Call Summit Racing and ask.
On the Summit Racing Web-Site... Normally there is a disclaimer next to product photos, stating that images may not correctly represent the actual product.
Old May 19, 2020 | 07:09 AM
http://www.northerndrivetrain.com/pr...3-3-5551X.html
Old May 21, 2020 | 06:55 AM
Summitracing's Avatar
LS1Tech Sponsor
Sorry for any confusion OP. The Spicer 3-3-5551X doesn't have the end of the shaft milled down. Here are the correct images and info direct from Spicer. We will get our images fixed so they match that of Spicer.
__________________
800-230-3030
www.SummitRacing.com
