6l80 to 4l80 wiring conversion???
Old Jun 17, 2020 | 08:47 PM
toddrparr's Avatar
Default 6l80 to 4l80 wiring conversion???
Hi all
I’m in the process of installing a gen 4 6.0/4l80 combo in my 69 Chevelle. The harness I have was from a truck with a 6l80e. Any cheap ideas on converting it. Preferably re-pinning and changing the connector, can find any decent diagrams online. I’m not running cruise or trans temp. Thanks!
Old Jun 18, 2020 | 07:35 AM
MaroonMonsterLS1's Avatar
LT1swap.com
Are you using the T42 TCM? If so, you should have an easy go of it...either finding a trans harness in a junkyard/used. Jolt, painless, current, etc. all can build TCM harnesses. or you can repin/build your own using LT1 swap.
You'll of course need to tune the TCM to pair with the 4l80e
Old Jun 18, 2020 | 08:20 AM
toddrparr's Avatar
I’m all set up for a 4l80e tcm wise. It’s just a re wire I need to do. I’ll check out your site. Thanks!!
Old Jun 30, 2021 | 10:20 AM
TqMnster's Avatar
Have just started researching the same swap for mine. It's simple getting the wiring diagrams for the t42/4l80 but finding diagrams for the 6l80 wiring is a little more difficult. $1k for a swap harness is crazy...
