single vs triple disc tq ?
Old Dec 6, 2020 | 02:31 AM
ls1 trex's Avatar
Default single vs triple disc tq ?
Hi
I wonder about the difference between a single and triple disc in tq ?
What is the difference between them And does the triple disc reduce the life of the transmission? and Can I use the car daily with it triple?
If the triple disc does not reduce the life of the transmission, and the car can be used on a daily basis with it Do I need a flywheel after market ?
Old Dec 6, 2020 | 09:16 AM
truckdoug's Avatar
it just adds more friction surface so you can lock the converter under WOT or while towing heavy.
you can daily a car with a multi-disc lock up system.
it should not decrease the life of the trans, unless of course being able to lock at WOT means you will abuse it more
speak with your converter manufacturer about what flexplate is needed for you application
Old Dec 6, 2020 | 10:54 PM
Dynamic396's Avatar
Just a stronger clutch in the converter. It's a good thing. I won't run anything but a triple disc converter in the diesel transmissions that I build.
Old Dec 6, 2020 | 11:17 PM
ls1 trex's Avatar
so can i run triple disk in stock 4l60e with daily drive ? without any issue
Old Dec 6, 2020 | 11:26 PM
Dynamic396's Avatar
Yessir... I do it every day (well, almost every day). Worst thing that would happen is an extra firm lockup.
