how cam I mimic a manual's throttle response?
Locking up a converter at 2000 rpms then going wot while still locked would be dog **** slow.
Going wot in a manual at 2000 rpms would be dog **** slow.
Imo I think a converter upgrade and possibly a gear change would do wonders.
Possibly other issues if it's 550 rwhp but only trapping 125 mph
Here is my setup, nothing sluggish about it....
Sorry folks, not yet a single recommendation for the brand and model TC with a 2000 rpm lock up and which will still let my LS7 idle in gear, brakes on. I would like this thread to lock up with that simple recommendation.
You just don't like the answer.
You need to just buy a 5 or 6 speed, sell your auto to someone who understands how things work, and move on.
Your auto is not a manual. It's not going to be a manual. It's not supposed to be a manual.
The TQ converter does work that a clutch CAN'T physically accomplish.
Just get a 3rd pedal and move on. I feel sorry for any converter company that gets you as a customer, it seems like the writing is on the wall, you'll be forever displeased.
https://getyarn.io/yarn-clip/0c00410...6-ea70b404999d
@FTI Converters
Sorry Dalton, here you go buddy.
Good luck
You need a converter that stalls enough so that buddy can get his 400 rpm 3psi oil pressure idle that sounds like a brick thrown into a dryer.
But you also need it to behave exactly like a manual car does.
Forget everything you know about making a converter that drives smoothly, and is actually fast when you want to step on the loud pedal.
Just build a converter that feels like a clutch
Good luck
The OP has probably put his 'dilemma' post on other car forums too and probably received all the same answers as on here and refuses to believe that you can't get an auto that acts like a stick.
If you want one that acts like a stick shift then get a stick shift. And even with a stick, how the front end jumps with blipping the throttle is gonna depend on what gear you're in. If you're cruising along in 2nd gear in city traffic and you blip the throttle, the front end is gonna jump because of the the higher rpm of the powerband because of being in 2nd gear and because of the torque multiplication of 2nd gear. If you're cruising along in 4th gear and blip the throttle, the front end is not gonna jump as much because you'd be at a lower portion of the powerband and because of no torque multiplication of a 1:1 tranny ratio.
OP: having scanned this thread and looking at what you are looking for, its not out of the realm of possibility even though it may not make sense to others. biggest limiting factor is going to be cam/gearing playing nice with however tight the converter is made. I saw gearing(3.73, probably 28" tire) but I didn't see cam specs. Do you have those? gross valve lift and duration at .050 is what i'm looking for.
-Dalton
-Dalton
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
I now have a contact in Dalton who I will try and contact. Thanks to 5.7stroker and vorteciroc for that, cheers.
-Dalton
-Dalton
Thanks for responding Dalton, saved me a call from Perth Australia. The cam is a proprietary grind by John Lloyd who is in fierce competition with other engine builders in Oz and the USA so he would not give me the specs. It has 315/35 x 17 tires or 25.7inch overall diameter. Suffice to say it dynoed at 553 rwhp from 6500 to 7000 rpm which corresponds closely with the 124mph trap speed for a 3,700 lb car with driver, given by the standard formula. It may have a mph or 2 more given that the 60 foots were 2.0 - 2.1 sec. It idles at 1000 rpm in drive right now brakes on. It has 1-7/8 inch primary long tube headers, a mafless tune, upgraded valve train and nothing else. The dyno sheet is attached, I manually added the torque figures after calculating them. You are right about my desires "not making sense to others". I have zero need for quick launches and would only ask for full throttle after 4000rpm on the street, same as if it had a manual. It is the very mushy part throttle response which just makes noise right now with a 3000rpm (maybe slightly higher) stall converter. That is where the tach instantly goes to, I was not given a spec sorry. My thoughts while driving would be that a 2000 rpm lockup would allow it to idle in gear brakes on hard of course. I hope you can help. Cheers.
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
Sorry I cannot be of more help. The cam would be close in spec to the 4th cam shown on these Crane specs as the peak power of 7000 rpm corresponds to mine as does the description. Also my builder said the LSA was too tight for a blower to be used which also corresponds with the 112 deg LSA shown. The current TC spec is unknown. It was just a generic locally built converter for which a 3000rpm lock up was specified. Cheers.
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
We'll try to make due with that. One other thing i was curious about, You keep saying "lock-up" on the converter being at a certain RPM, Are you referring to actually turning on the lock-up clutch inside the converter? Or just the RPM at which the converter becomes most efficient and slipping is to a minimum? It appears what you call being locked up is actually converter stall or "efficiency" rpm but rather than assume i would rather clarify first.
On my 98Z with the OEM factory converter (1800 stall rated) and 3.23 gears, 'blipping' the throttle would cause the front end to 'jump up' as a stick shift would. When I put a TCI 'breakaway' 2800 in, all that 'jump' was lost due to slippage inefftciency ( but still running the 3.23 gears). When I put a 4.56 rear end in (with that TCI 2800), some of the front end jump up returned because of the now better mechanical advantage of the powertrain over the weight resistance of the car, but it wasn't like the OEM converter with 3.23 gears..Next was a Yank SS3600 and that brought the front end jump almost all the way back (with either 3.23s or 4.56s'). So it depends on the built in looseness/tightness of the converter.
That's why I asked what car and what converter in a previous post.
It is not a popular configuration (except for in a few specialized racing classes) but...
The clutch assembly (Fly-Wheel, Pilot-Bearing, Friction-Disk, Pressure-Plate, and Hydraulic Throwout-Bearing) from a Manual-Transmission can be mated and used with an Automatic-Transmission.
The clutch would have to be released when the vehicle is stopped/ slowing-down to a stop...
Then the transmission would do all the shifting on its own (without using the clutch).
On another note... If anyone here needs a Turbocharger repaired or rebuilt at this time...
send me a message (as I am making a run of this now, and only do a large batch twice a year).
Am I asking too much to have the TC lock up with no slipping at only 2000rpm? I only need lock-up at part throttle, that is to say not enough throttle to cause the trans to kick down. If it needs to slip at full throttle it doesn't bother me because I would never apply full throttle below 4000 rpm in any case. It is the feel of a direct connect with the throttle at lower rpms on the street that I want. Cheers.
We call lock-up applying the clutch inside the converter, this is essentially just like a manual clutch with a 1:1 ratio(no slip). if this is in fact the type lock up are wanting then as was mentioned in post #2 you will need a triple disc lock up converter, any stall setting will work, and a tuner to tune the lock-up function as you desire.
Now what I BELIEVE you are calling "lock-up" is actually what I described before as converter efficiency or minimal slippage at a certain RPM for that power input. IF that is the case then this is really easy and a simple tight 9.5" or 10" blower type converter will be the ticket as it comes together very early in the RPM band and will offer the minimal slip at a lower RPM you desire.
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
Asking too much? No, anything is possible... makes sense? no, that's why I'm asking for clarification on what you are calling "lock-up" because my version,and the version of "lock-up" for everyone else here. APPEARS to be different from what you are perceiving as lock-up...
